Interior drivers door handle
Old 11-20-2011, 01:01 PM
69 F100 Cali's Avatar
69 F100 Cali
69 F100 Cali is offline
Well the door handle doesn't work on the inside with the handle so for the time being I took the panel off and just pull on the linkage from the inside. This makes me think that it is loose since pulling the linkage still opens the door but the handle doesn't. The problem is when I was putting the handle on I torqued one of the bolts to much and both threads broke off and it looks like the threads were part of the door itself so do I have to get a new door now??
Thanks!
Old 11-20-2011, 02:09 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Drill out the broken bolt and re-tap it.
Alternatively, use a threaded insert or "riv-nut" or "nut-sert". Basically, it's a threaded rivet. In California, visit Ace Hardware for an insert kit (like $8 IIRC).
Here's a before and after of a threaded rivet:
Old 11-20-2011, 08:42 PM
69 F100 Cali
oh wow i didnt even think of that thanks!
DisneysPatB
11-22-2017 06:43 AM
Bluey Zedoff
15
09-29-2014 07:24 PM
jchosler
02-28-2011 01:02 PM
MsParker
1978 - 1996 Big Bronco
02-21-2008 09:19 PM
davvalh
10-21-2002 08:16 PM
Quick Reply: Interior drivers door handle
