Towing Capacity help
Old 11-12-2011, 05:47 PM
johngeorge's Avatar
johngeorge
johngeorge is offline
Rear axle code on 06 EB Expedition is "15". I found out that is a 3.31. The salesman at the Ford dealer we purchased this from told me it would handle the 8,950# rating since it is an EB model. Anyone know what the actual rating is?
Old 11-12-2011, 05:48 PM
Supercab's Avatar
Supercab
Supercab is offline
Might check in your owners manual, I know its listed in there for my F350.
Old 11-12-2011, 07:16 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
I hate to assume but the 3.31 was only available in the 2WD model. Assuming yours is a 2WD and the 3.31 is the correct ratio, according to the 2006 Ford Trailer Towing Guide your maximum trailer weight is 6,000 lbs. the maximum for the 2WD with 3.73 gears is 8,900 lbs., the maximum for the 4WD with 3.73 with the Heavy Duty Towing package is 8,600 and it's 6,000 without the HD Trailer package.
The dealer is wrong. The Eddie Bauer package has nothing to do with it.
By the way, you can download a copy of the Towing Guide here:
https://www.fleet.ford.com/showroom/...06_default.asp
Old 11-12-2011, 10:39 PM
johngeorge's Avatar
johngeorge
Thank you for the info.
Old 10-22-2014, 02:54 PM
Jamshi's Avatar
Jamshi
Jamshi is offline
John, I own a 2006 Ford Expedition Limited 4WD. Looking at the vehicle tag it says I have an H6 axle which I believe translates to a 3.73 Limited Slip gear & ratio. I have all but concluded that my towing capacity is at least 8,600 lbs. I have the factory installed tow package. What I am trying to determine is if there are actually two types of tow packages... standard tow package and heavy duty tow package. I need help in determining which one I have? I am towing a Jayco Jay Flight TT which has an unloaded weight of 6,676 lbs and a GVWR of 8,500 lbs. Thanks for any help you can give.
Thanks,
Jim
Old 10-23-2014, 05:19 AM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
Towing guides have moved now to this location:
Towing Guides | fleet.ford.com
For 2006 click on it and go to page 20. It indicates 8900 lbs with the heavy tow package. There are two gear sets. do you have your window sticker to see what you have?
Old 10-23-2014, 07:59 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
What he said ^^^
and if you don't have your window sticker, try your vin here --> Ken Wilson Ford Serving Asheville & Waynesville, NC, New, Used Cars - Window Sticker Lookup Tool
Old 10-23-2014, 01:31 PM
Jamshi's Avatar
Jamshi
Jamshi is offline
My sticker indicates my axle ratio is H6 which I understand is the 3.73 limited slip. Since I have a 4X4 appears from the tow guide that my tow rating with the heavy duty tow package is 8,600 lbs.
Jim
Old 10-27-2014, 12:39 AM
r2millers's Avatar
r2millers
r2millers is offline
I don't believe Ford has ever made both a standard and a heavy duty towing pkg for the same vehicle. It's either towing or not.
Old 10-27-2014, 04:56 AM
senix's Avatar
senix
senix is online now
I think for those years it would have an added trans cooler.
Old 10-30-2014, 11:56 AM
meborder's Avatar
meborder
meborder is offline
a little late to the party here, but here's what I've been able to find out about mine:
all expeditions of those years came with either the standard towing package, or the HD towing package.
the standard towing package comes with either 3.31 or 3.73 open gears, 4 pin connector and a 8 row transmission cooler. towing capacity for this combination is 6,000 lbs regardless of gears or package.
the HD towing package comes with 3.73 Limited Slip gears, 4 pin and 7 pin connector and an upgraded transmission cooler (14 row IIRC). towing capacity for this is 8900 4x2 and 8600 4x4.
after much research on mine, that is the best information I have found.
Old 10-30-2014, 12:18 PM
r2millers's Avatar
r2millers
In 99, my optional pkg for 880.00 was called a "trailer towing package." They didn't differentiate between HD and Standard.
Sounds like later models used different vernacular.
Mini1298
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
13
02-26-2018 07:24 AM
Finler
2009 - 2014 F150
01-19-2011 03:20 PM
aking225
09-19-2010 10:09 PM
rknight29
1997-2006 Expedition & Navigator
04-23-2004 10:13 AM
juhasz
03-31-2003 08:51 AM
Quick Reply: Towing Capacity help
