Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-12-2011, 11:03 AM
baumst baumst is offline
1960 Ford F-100
baumst is starting off with a positive reputation.
How many quarts should my rear differential take?
I had been eye balling the drops of oil out of my rear diff and that is probably the next project.
My 1960 F100 rear diff. I am pretty sure it is a 9". How many quarts should it take? (seeing as I do not have a shop manual)
I got the bolt loose and dropped a quart in and I am astonished that it is still not full! (though I could be the first person to open it in 20 years)
I going to town to get more and maybe something to suck it all out for a complete change.
Anyone use that Lucas Oil Gear stuff?
  #2 (permalink)
Old 11-12-2011, 11:35 AM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
In Memoriam.....
Garage is empty, add now
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Baumst, I never used the Lucas product.I'd be inclined to just stay with standard 80/90 wt gear oil,unless I was starting from scratch with a rebuild.At any rate,it won't heal any noises/problems.
Also,can't say how much the diff will take.I buy a gallon with a pump,and pump slowly till it comes out the fill plug,seal it back up and good to go.It's usually cheaper for a gallon,and I can also use it in the tranny.
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Entitled, self-absorbed kids - meh."
  #3 (permalink)
Old 11-12-2011, 11:43 AM
1960 Ford F-100
Yeah... that's what I am thinking... pumping it in. The quart I put in was shocking. There is no issue, no noise... no anything. I am just thinking...."Drops on drive way, change gasket project. Better check oil level." Cool stuff...
Niners beat Giants this weekend... They are the real deal.
  #4 (permalink)
Old 11-12-2011, 01:52 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
I would sooner think it is the pinion seal unless you can see it is dry.
Let's hope so about those G-men!
  #5 (permalink)
Old 11-12-2011, 01:54 PM
spurredon's Avatar
By the way, I believe it should hold somewhere between 2 and 2 1/2 quarts.
  #6 (permalink)
Old 11-13-2011, 10:55 AM
1960 Ford F-100
Ended up down 1.5 qts. Nice. Except for ripping the head off the engine... I think I have been everywhere to make this reliable.
Tags
2003, 2005, axle, diff, differential, end, f150, ford, gear, hold, lube, quarts, rear, superduty, take
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
