97 F 350 powerstroke ignition wiring problem
They say I'm a new member, but I actually joined months back. They tell us to identify our vehicle and something about it. Here's the "scoop." I purchased new this 97 F350, CrewCab, 4x4, auto tranny, with a 7.3 back in 97. I had a dually conversion done on it. Was a great truck except tranny did not make it past 100k. I drove it 118,000 miles, and sold it when I replaced it with a 99. I just have bought the 97 back with 217,000 miles. Was sitting in the back yard of the fellow who bought it from me. Five years without being started. I traded a 99 burb to get it back. Put in two new batteries, and replaced a frozen starter, and cranked it. Took a few tries, but it fired up. "Hiccups" at first starting for about 5 seconds then starts (deal with that later), but then evens out and sounds like a great 7.3.
Here's my issues to be resolved at this point. (May be more along the way). The steering column was dangling, the ignition switch would energize the dash lights and accessories, but would not energize starter. It is not sending power to the starter solenoid. Solenoid energizes when I run a jumper from the battering to the solenoid. (That's how I started it.)
Truck had a viper alarm which worked fine in my original days, but now kept clicking off and on (siren was disconnected) so I thought that the "starter kill" might be keeping the starter from engaging. I'm not real "sabe" on alarms but I removed the alarm when I removed the steering column. In the alarm install, only one wire was actually cut to run through the alarm. I spliced it back together. All other wires were just "T"-ed into various operational wiring.
So now after disconnecting the 4-wire harness to the key ignition, I would think that I could at least find a "hot" wire in those 4 wires, jump it over to another to energize the accessories so I could run my window up again. But I can't find any wire that will do that.
Is there any electrical wizrds that can tell me the wiring path of my ignition wires? There are 4 wires running to the key ignition harness, and three wires connected to a switch farther down the steeringcolumn. Sorry for the "book" here, but now you have the story.
Thanks.
Thanks.
69highboy69
12-15-2012 10:04 AM
dlsweet
11-12-2011 08:52 AM
slowjet
1999 to 2016 Super Duty
01-02-2011 02:21 PM
