What oil do I use? - Ford Truck Enthusiasts Forums
What oil do I use?
Old 11-12-2011, 08:08 AM
mr.fordneck's Avatar
mr.fordneck mr.fordneck is offline
mr.fordneck is starting off with a positive reputation.
What oil do I use?
1990 F150 5.0 196,000 on new used engine. What type of oil (synthetic, part synthetic, or conventional) should I use? What viscosity should I use (5w30, 10w30, 10w40) I've used fully synthetic and conventional but I want to double check since I have no owner's manual
Old 11-12-2011, 08:13 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
I run Mobil 1 full synthetic 10w30. Everyone has different opinions on what oil though.. there are a few threads on oil already.
Old 11-12-2011, 08:21 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Quote:
Owners manual for a 1994 calls for basically 5w30 in the winter months and 10w30 for the summer.....
Old 11-12-2011, 09:50 AM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
sidewinder you say 5w30 in the winter is that for any of the engines or is that for the 4.9 ive just never heard of that big of a change from winter to summer. and none of my trucks have a book
Old 11-12-2011, 10:00 AM
Quote:
Its a general thing...THinner oil for easier operations, and thicker oil in summer for extra protection...Heat an what not...
Old 11-12-2011, 10:31 AM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
With that many miles on it, I would not use 5w30 at all. It's too thin and may not hold enough oil pressure. I would run 10w40 year round. If it hasn't had synthetic in it every time since it was new, do NOT change over now. It will leak oil from every gasket if you do.
Old 11-12-2011, 10:38 AM
Quote:
The man speaks truths...lol
Old 11-12-2011, 10:42 AM
deljac's Avatar
andym. ive changed every vehicle ive owned for the last 12 years or so over to full synthetic when i get them and have never had any leaking problems. my blue 95 had 123000 miles on it when i got it and when it got wrecked it had 158000 and never had any leaks
Old 11-12-2011, 10:43 AM
Previous Ownership goes a LONG ways...
My current truck....I saved...Quite literally...
My 1994...The PO's were family friends....An older gentleman and his daughter.....Both were easy on the truck, and it showed...
Old 11-13-2011, 12:11 PM
Turx Turx is offline
Turx is starting off with a positive reputation.
I like the Motorcraft Synthetic Blend oil along with Motorcraft filters. Newer Fords call for 5W 20, 5W 30, older 10w 30 or 40. I stick to what the Owners Manual calls for, while my son disagrees with me on the oil weights, I have never had any problems. I try to change around 3500 miles.
Old 11-13-2011, 06:07 PM
95f2504x4's Avatar
95f2504x4 95f2504x4 is offline
95f2504x4 is starting off with a positive reputation.
My 95 I run 5w20 Valvoline full synthetic in and have no leaks at all and my truck was a beater truck that was lucky to get it's oil changed every 6000 to 8000 miles with 5w30 conventional once again like above stated it's all a preference thing. I work for Valvoline and have seen the tests on oils it's pretty crazy when u get the graphs and all the info complete together and that's why I use what I use. But in a 90 the recommend 5w30. I use 5w20 because my truck falls in the years for the tsb that ford put out
Old 11-13-2011, 06:19 PM
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
Quote:
I could never put glorified canola oil in my truck but different strokes for different folks
In the 96 302 its trop-artic semi-syn 10w30, 96 300 rottela-t 10w30 for the zinc addative they both get napa golds and changed 2800-3200 miles
Old 11-13-2011, 06:29 PM
95f2504x4's Avatar
Trop-artic....... That's gas station oil ..... Talk about canola oil....... I'd put mobil in my truck before I'd get close to using that. Ashland makes some of the finest oils in the world and with all the research that is done they stay ahead of everyone else.
Old 11-13-2011, 06:38 PM
You always take things offensive I was talkin about vescosity not brand..... Some people
Old 11-13-2011, 06:44 PM
95f2504x4's Avatar
Lol sorry that was my bad but if u look up for my truck it reads 5w30 for when it came out but ford put out a tsb basically saying 5w20 superceeds the previous recommendation of 5w20 that's y I use it.
Switching to synthetic oil on high miles SweetPete531 3.8 & 4.2L V6 6 09-23-2015 07:37 PM
Transfer Case Oil ?? jhid101968 Escape & Escape Hybrid 1 03-29-2015 03:24 PM
synthetic oil? Leatherneck007 1994.5 - 1997 7.3L Power Stroke Diesel 3 08-10-2014 08:57 AM
4.9 Oil change. What type? rangertokey Oil & Lubrication 14 12-17-2012 09:36 AM
Synthetic 5w40 Skinner F350 6.0L Power Stroke Diesel 44 02-27-2011 06:09 PM
Tags
188000, 1956, 1990, 1992, 351w, 4x4, 50, f150, ford, miles, motor, oil, truck, trucks, viscosity, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
