What oil do I use?
Its a general thing...THinner oil for easier operations, and thicker oil in summer for extra protection...Heat an what not...
The following users liked this post:
My current truck....I saved...Quite literally...
My 1994...The PO's were family friends....An older gentleman and his daughter.....Both were easy on the truck, and it showed...
I like the Motorcraft Synthetic Blend oil along with Motorcraft filters. Newer Fords call for 5W 20, 5W 30, older 10w 30 or 40. I stick to what the Owners Manual calls for, while my son disagrees with me on the oil weights, I have never had any problems. I try to change around 3500 miles.
My 95 I run 5w20 Valvoline full synthetic in and have no leaks at all and my truck was a beater truck that was lucky to get it's oil changed every 6000 to 8000 miles with 5w30 conventional once again like above stated it's all a preference thing. I work for Valvoline and have seen the tests on oils it's pretty crazy when u get the graphs and all the info complete together and that's why I use what I use. But in a 90 the recommend 5w30. I use 5w20 because my truck falls in the years for the tsb that ford put out
In the 96 302 its trop-artic semi-syn 10w30, 96 300 rottela-t 10w30 for the zinc addative they both get napa golds and changed 2800-3200 miles
I could never put glorified canola oil in my truck
Trop-artic....... That's gas station oil ..... Talk about canola oil....... I'd put mobil in my truck before I'd get close to using that. Ashland makes some of the finest oils in the world and with all the research that is done they stay ahead of everyone else.
