How to change mileage on new ODOMETER - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-12-2011, 06:42 AM
KX123 KX123 is offline
KX123 is starting off with a positive reputation.
I just picked up a used odometer from a 2005 f350 T.D. wreck, the mileage reads 56,342 ,my original reads 235,047. Can anyone tell me how to get the used one to read the same as the original?.. Trying to keep it honest
Old 11-12-2011, 08:35 AM
sailorman3 sailorman3 is offline
sailorman3 is starting off with a positive reputation.
No possible way. That is to keep people honest. Dealers will just put on a sticker next to the speedo with the old mileage on it.
Old 11-12-2011, 10:02 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I would bet if a dealer installs it that Carfax would also pick it up, all of them I have seen say "Add xxx miles"
Old 11-12-2011, 11:10 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Your not going to get the odometer to match, can't change mileage numbers. If the mileage could be changed every shady car dealer would be turning back odometers to make the vehicles worth more. A relative had one changed on his crown vic at the Ford dealer. The new odometer started at zero so you had to add the old odometer mileage to get the actual number. Since he used the dealer it showed up in an oasis report.
Old 11-13-2011, 08:41 AM
Pappy1911's Avatar
Pappy1911 Pappy1911 is offline
Pappy1911 is starting off with a positive reputation.
Quote:
I guess I won't be buying anything from this person....
Old 11-13-2011, 08:48 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Why? He's trying to get the odometer he wants to install to read the actual mileage that's on the truck. What's wrong with that?
Old 11-13-2011, 08:52 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
I was thinking the same thing. It would be different if he was trying to roll an odometer back but he's trying to get the used one he picked up to reflect the actual mileage of the truck.
Old 11-13-2011, 09:07 AM
Pappy1911's Avatar
Folks, this is the internet, don't believe everything you read is Gospel...just saying...
Old 11-13-2011, 09:26 AM
Quote:
No kidding. But to automatically assume the OP is lying isn't very fair.
Old 11-13-2011, 10:06 AM
Pappy1911's Avatar
Quote:
No, I'm not calling him a liar, but there are such people out there. My point is, buyer beware!!!
Old 11-13-2011, 12:33 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
Of course, if you really wanted to roll back the odometer, it's as easy as what the OP just did. Find a lower mileage cluster from a junkyard. That's why we have Carfax.
Old 11-13-2011, 12:51 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
It's just a piece of non-volatile memory. Saying it is impossible to get at and modify the bits is very difficult to believe.
However, all of the tools I've found in the last few minutes each run over $6,000. Have you asked a dealer yet? If they know your story, and can verify the actual mileage of the vehicle, I'm sure they can make the "new" one match.
I don't know what the limit is now, but at some point the mileage no longer matters, and the vehicle becomes "exempt"... that point used to be 100,000 miles, but that was back when odometers only had 5 digits + tenths.
Old 11-13-2011, 01:13 PM
kd0axs's Avatar
I'm sure it's one of those things that varies by state. Here in MN, mileage is required on the title for all vehicles less than 10 years old. When selling a vehicle, you have to declare the current mileage and sign off on it. You also have to mark a box that indicates whether it's the actual mileage, the mileage in excess of the odometer's limits, or not the actual mileage. If the vehicle is more than 10 years old, you don't have to declare the mileage.
Old 11-13-2011, 01:38 PM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
there are speedometer services usually used by rebuilders which can do it by sending them the cluster. they use a pc with a special program , and they have harnesses which plug from the pc into your cluster, and with a few keystrokes its done, simple,huh?
Old 11-14-2011, 09:07 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
92f150I6 is gaining momentum as a positive member of FTE.
So what does a person do if their origional cluster quits working?
Powering up reading odometer JRS2 1987 - 1996 F150 & Larger F-Series Trucks 4 04-12-2016 10:10 PM
Odometer memory stored where? Todd T 1987 - 1996 F150 & Larger F-Series Trucks 4 12-30-2014 07:30 PM
odometer memory not in cluster? kengarchow 1999 to 2016 Super Duty 0 07-02-2014 12:33 AM
Miles vs Kilometers (U.S. To Canada) pbuzz3323 General Automotive Discussion 6 02-21-2004 07:57 AM
new used odometer reading bjoern 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-09-2001 08:44 PM
Tags
150, 2006, adjust, car, change, econoline, ford, mileage, odometer, original, replacee, set, speedometer, truck, update
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
