Tachometer on V-10 engine - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 04-12-2003, 01:42 PM
Hopcraft Hopcraft is offline
Hopcraft is starting off with a positive reputation.
Need information on where to hook up a Tachometer on a V-10 engine. I have a E450 cutaway and am adding the Tach.
Is there a specific contact on the data terminal for the tach
Old 04-14-2003, 06:55 PM
V10KLZZ71S's Avatar
V10KLZZ71S V10KLZZ71S is offline
V10KLZZ71S is starting off with a positive reputation.
GO to Ford racing or Saleen or any of the mustang suppliers an get a tach adapter-about 50 bucks.Where it hooks up i dont know but should be in the instuctions.Enable you to hook up any kind of tach to a distributerless ignition.
Old 04-16-2003, 05:16 PM
vern kelly vern kelly is offline
vern kelly is starting off with a positive reputation.
Cool Tachometer on V-10 engine
I installed an Autometer Tachometer on my Dad's E450 class C motorhome with Ford V10. The gage was previously on a Chevy V8 motorhome. I had to send it back to Autometer to be calibrated for 5 pulses per revolution. Cost was ~$30.
The instructions were on Autometers web site but does not explain everything. You must tap into pin42 of the computer connector which is in the engine compartment on the drivers side. This is a 104 pin plug. Pull battery cable neg side before disconnecting this plug. you must pull this connector because the pin wiring is labled on the back side of the connector. You will want to tap into the wire connected to pin 42 (red and white) for the signal wire.
If you do a search on this forum for Tachometer or Aftermarket gages you will find my detailed description.
Ford must be saving money not installing tachs on van chassis.
Worked great after about a 4 hour install!
1998 Dodge qaud cab 2500 V10. 3.55 gear
Old 04-17-2003, 06:24 PM
Thank you for the information. I will get into the hookup this weekend. I purchased a Tach that had a dip switch in the back to set for 10 cyl. But the instructions were very vague for the tach lead.
Old 04-18-2003, 01:59 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Question Tachometer on V-10 engine
Hey Hopcraft;
Where did you find your tach? Also what mfg. and model? I have been looking around for one to place in my E-350.
Old 05-06-2003, 11:53 AM
Sorry about the delay in answering you, I have been traveling and not able to see my email.
The tach is a SUNPRO CP2010 or CP 2012
Actron Manufacturing Co
15825 Industrial Parkway
Cleveland, OH 44135 There was no phone or web on thier literature. These tachs are avail through most speed shops and some auto parts stores.
Old 05-06-2003, 02:45 PM
Muffler Mike Muffler Mike is offline
Muffler Mike is starting off with a positive reputation.
I have been going thought the same thing on my v-10 van.
talking to the guys at Autometer, that pin 42 or what ever i is, is correct. the white with pinkish red stripe. but they also told me to look on the firewall. (actually right at the edge of the hood) and look for the same color wire that is labeled CTO or clean tach output. This is what i will be using. just a dangling wire with a shrink wrap cover on the end.
hope that makes it easier then looking for pin 42. (although i didnt even look for that pin.)
Old 05-07-2003, 09:55 AM
That is really good news as I found the CTO wire and hoped that that was the one. I will hook up there.
Hopcraft
Old 07-17-2003, 09:42 AM
R66 R66 is offline
R66 is starting off with a positive reputation.
I puzzled over the V-10 tach problem for nearly a year, even went to a Ford dealer and talked to several technicians. They couldn't tell me anything. Then found the little white and pink CTO wire peeking out under the edge of the hood over the firewall. Pulled on it and found a stub wire with a the label on it with the legend "CTO" popped out. Connected it and the tach worked fine.
V10 tachometer rclarke 1968-2013 Full Size Vans 5 05-25-2014 11:49 PM
Tachometer issue resolved boonslick 1987 - 1996 F150 & Larger F-Series Trucks 2 10-30-2013 12:38 PM
Which fuse for the tachometer? AbandonedBronco 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 11-26-2012 01:26 PM
Tachometer Problems? banjopicker66 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 03-25-2010 10:29 AM
tachometer on 5.4L engine terragate Modular V8 (4.6L, 5.4L) 3 01-04-2002 05:41 PM
Tags
07, add, dip, e350, e450, f150, ford, install, settings, sunpro, switch, tach, tachometer, v10, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
