Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-11-2011, 10:06 PM
F250racer's Avatar
F250racer F250racer is offline
Garage is empty, add now
F250racer is starting off with a positive reputation.
57-60 fuel guage
Looking for a new fuel gauge for my '59. I have the stock sender with the stock gauge but that gauge just went out. Eventually I'd like to find all new gauges but right now I'm looking for the cheapest gauge that can take it's place.
Does anyone have a napa part number for a gauge compatible with the stock sender?
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
  #2 (permalink)
Old 11-12-2011, 05:26 AM
transam525 transam525 is offline
transam525 is starting off with a positive reputation.
Believe it or not, you can usually find an NOS gauge for around $25 or less. They appear quite frequently on E-bay, however you're at the mercy of another's highest bid. Dennis Carpenter (highest prices), Miller Obsolete, and Green Sales (lowest prices) should have at least one in their NOS stock. I don't have my books with me for a part number at this time, however if you contact Mr4spdFord or NumbersDummy, they can provide you with an OEM part number to use when inquiring.
__________________
1960 Ford F-100 with Custom Cab, Styleside short bed, 292 2-bbl, and three speed transmission.
1978 Pontiac SE Trans Am, t-tops, Pontiac 400, and Turbo 400 transmission.
  #3 (permalink)
Old 11-12-2011, 09:58 AM
F250racer's Avatar
How do I know if that's a fuel or temp gauge? Do they both have the same ohm range(making them interchangable)? I don't have it infront of me but I'm pretty sure mine says "fuel" at the bottom of the guage face when it's removed from the cluster.
__________________
Colin
  #4 (permalink)
Old 11-12-2011, 10:17 AM
hawk1959's Avatar
hawk1959 hawk1959 is offline
RATROD58
1959 Ford F-100
hawk1959 is starting off with a positive reputation.
i was checking that guage out that is a Fuel guage the temp guage only has 3 lines , i looked at mine and its the same as my Fuel guage
  #5 (permalink)
Old 11-12-2011, 10:32 AM
Disregard the E-bay link, as I just noticed I copied an incorrect page (amp gauge). The gauge itself has no wording, only an orange needle and white hash marks. Inside the cluster is a metal bezel that surrounds the gauge and displays the appropriate lettering for what the gauge displays at the bottom. The gauges are different, and not interchangeable. The ohm readings differ as do the mounting bracket orientation on the gauge itself.
The cluster consists of the housing, three cardboard tubes to contain the lighting for the high beam indicator, OIL, and GEN lights, the speedometer, temp gauge, fuel gauge, high beam, OIL and GEN lenses, surround bezel, and the glass. To swap the gauge, unplug all gauge and bulb connections from the rear, un-snap the speedometer cable, and unscrew the outer screws of the front instrument cluster panel. Remove the entire panel with cluster attached. Once removed, unscrew the temperature gauge from the rear, remove, and install the new cluster and re-assemble. Personally, I wouldn't bother with trying to install an aftermarket parts store gauge. Even if an NOS or used gauge costs more, the time saved without having to wire in an entirely new/different gauge is money well spent.
__________________
  #6 (permalink)
Old 11-13-2011, 01:27 PM
F250racer's Avatar
Thanks, yea eventually I'd like to find all brand new guages to put in but just haven't found ones I like yet.
For now I'll just keep an eye out for a NOS stock fuel gauge.
__________________
Colin
  #7 (permalink)
Old 11-15-2011, 10:16 PM
ibuzzard's Avatar
ibuzzard ibuzzard is online now
We'll Always Have Poway..
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Here's an NOS fuel gauge, in the correct color.The post lists it as an ammeter,I think it is for fuel.Ask the seller for the Ford part number to cross check it:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Edit note: Sorry,this is NOT a fuel gauge, but an (optional?) ammeter as the seller stated.
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Show me your Tee-Hee, I'll show you mine."
  #8 (permalink)
Old 11-26-2011, 01:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1957/60 F100/1100 Dash Fuel Gauge.
C0TF-9280-B (replaced B7C-9280-A) .. Dash Fuel Gauge / Obsolete
Last MSRP: $43.42 / Dealer net cost: $26.05.
Note: C0TF-9280-B was the 1960 FoMoCo service part replacement for the guage used 1957/59 (B7C-9280-A). I do not know what color the dial is.
C0TF-9280-B =
COLLECTORS AUTO SUPPLY in Oroville WA has ONE = 800-414-4462.
TISON MOTOR CO. in Estill SC has ONE = 803-625-2551.
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
No other Ford Dealer or obsolete parts vendor has any.
B7C-9280-A =
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
No Ford Dealer, no other obsolete parts vendor has any.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #9 (permalink)
Old 11-26-2011, 09:59 PM
ibuzzard's Avatar
There you go,Colin.I'm going to go after one of those on Monday to add to my parts shelf.Thank you,Bill!
__________________
  #10 (permalink)
Old 04-29-2012, 08:10 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Did any of you guys buy one of these guages NumberDummy pointed to? I was wondering what color face they had.
  #11 (permalink)
Old 04-30-2012, 12:03 PM
Ford Parts Guru
2013 Ford Escape
Quote:
Originally Posted by NumberDummy View Post
C0TF-9280-B =
B7C-9280-A =
Quote:
Originally Posted by spurredon
Did any of you guys buy one of these gauges NumberDummy pointed to? I was wondering what color face that had.
No one including cheapskate ibuzzard bought any, cuz I just checked. The above suppliers still have the same quantity.
So, maybe you could call and ask what colors the faces are.
__________________
  #12 (permalink)
Old 04-30-2012, 08:36 PM
ibuzzard's Avatar
I prefer "thrifty". You know, like Jack Benny.
__________________
  #13 (permalink)
Old 05-02-2012, 04:39 PM
spurredon's Avatar
I guess I can't blame the Steve for not buying one. I called the first place and the price was $125.00! I thought it was a tad high. The next two places I called, I was not able to get a price since the persons I needed to talk to were either in a different building or out for the rest of the day. I am not too hopeful witht the first price though. I have a '59 guage from my parts truck but it is not the color I want for the '60. Although, I could get use to it for $125 plus shipping! I didn't call on the one in Texas with the older part number as I would think that would have the dark face as well.
I guess I'll join the cheapskate club! What are the dues Steve?
  #14 (permalink)
Old 05-03-2012, 09:08 PM
F250racer's Avatar
yea I just got an NOS '60 fuel gauge(gray back) on ebay for $26.
__________________
Colin
  #15 (permalink)
Old 05-03-2012, 10:16 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Awesome, Colin.... Very Thrifty! As big as this country is, ok the world is, it's nice to know there's an F350 fridge guy on another island in Puget Sound. My fiance was born and raised on Vashon Island and her sister still lives there. I know we will meet one day and maybe do a fridge rendezvous on Vashon!
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
Tags
1959, 1960, 1966, exchangeable, f100, f250, ford, forum, fuel, gas, gauge, muve, needle, parts, temperature, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
