Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 11-11-2011, 03:28 PM
LightningFast LightningFast is offline
Garage is empty, add now
LightningFast is starting off with a positive reputation.
Cool 2000 Lightning PCV hose replacement??
Do I really have to remove the whole blower intake just to replace a worn out PCV vacuum hose?? Seems totally insane. Everyone says i do, 'cause I cant the the secondary part of the hose back into the rear of the intake. any help would be appreciated.
  #2 (permalink)
Old 11-13-2011, 10:33 AM
Nobody out there has any suggestions or advice on this?? This seems like just a minor maintenance issue, I really don't want to have to take off the intake to put this hose back on!! Nobody here at FTE has had to replace this PCV hose before??
  #3 (permalink)
Old 11-20-2011, 09:22 AM
slammedi'am's Avatar
slammedi'am slammedi'am is offline
slammedi'am is starting off with a positive reputation.
It is on the back of the intake down low...You maybe able to get by with just pulling the s/c...I had to take my intake off and noticed mine was bad so I went ahead and replaced it while it was torn down.
__________________
www.TrueBlueTrucks.com
  #4 (permalink)
Old 11-20-2011, 12:40 PM
Eds56Effie's Avatar
Eds56Effie Eds56Effie is offline
Eds56Effie is gaining momentum as a positive member of FTE.
I was able to replace mine by just removing the blower..a tight fit back there but certainly doable. Good luck!
__________________
1956 F100 Restomod
2001 Ford SVT Lightning
http://www.picturetrail.com/eds01lightning
Tags
2003, 46, changing, elbow, ford, hose, lighting, lightning, lt, pcv, prefilter, pvc, replacement, replacing, svt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
