Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-11-2011, 02:08 PM
seethrough seethrough is offline
Garage is empty, add now
seethrough is starting off with a positive reputation.
Newbie with a couple of 65 "projects"
Just wanted to say hello. Been watching the forum for awhile and finally got around to registering. I have had really good luck with other auto projects with the help of forum members at other sites and I am sure that this site will be as rewarding as the others.
The first project is a 65 5 window that I just picked up a few weeks ago. The plans are to convert this to an EV. My work allows me access to a large quantity of free, lightly used VRLA batteries so the idea is to install either an AC or DC motor in place of the 6 cylinder and beef up the suspension/frame to support the battery weight. Currently looking at replacing the uni-body frame with a 2x3" tube frame and notching the rear so the truck can be lowered a little. Some 20x10 rear wheels and ??? front wheels to give it some attitude. Also looking at possibly using a Jaguar independant rear differential and a custom air bag setup. Will definately be throwing some questions on the forum about front suspension options.
The second project is a 65 3 window that will be a mid engine with transaxle. Again a slightly lowered truck with a Cobra 32 valve engine tied to ??? brand transaxle. This will be at least a year or two down the road but like my other projects I tend to always be thinking through designs/options and collecting parts until the project starts. Inputs are welcome - I expect there will be some responses about "grand ideas" so to those that wish to make them will just need to patiently wait and see the progress.
I look forward to being part of the econoline community and really look forward to input on projects, especially once I get some of the design ideas progressed into parts and start the work.
Click the image to open in full size.
  #2 (permalink)
Old 11-11-2011, 05:43 PM
EmilBarnabas EmilBarnabas is offline
EmilBarnabas is starting off with a positive reputation.
I'm looking at electrifying a '64 Econoline.
Are thinking of putting the batteries under the truck or in the bed?
I don't think you will need to beef up the frame in order to install the batteries, unless you are planning on loading up the pickup bed with occasional cargo.
Removing the 200 pound weight above the gas tank will give you additional room for batteries.
  #3 (permalink)
Old 11-12-2011, 10:26 AM
Nice to know that I am not alone in this insanity. Havent worked out all the details on the battery placement because it will greatly depends on what type of motor I run. The only constant right now is that I will be using 12V 78Ah VRLA batteries because I have a continuous supply of good used ones through work. I am looking at swapping the frame if I end up going with an AC motor because the voltages are typically higher than those of a DC motor and this will result in an increase in total battery weight. I would like to be able to build "saddle" shelves for the batteries that would fit over each fram rail and sit below the bed but again this depends on how many batteries I eventually need to support the motor. I am really pressing towards beefing up the frame and going with an AC motor so I can have some regenerative braking and just for the fact that the AC motors are so far advanced over the DC units.
  #4 (permalink)
Old 11-12-2011, 09:27 PM
I'm also leaning towards the AC motor and keeping the batteries under the floor.
I also think I can keep the AC motor below the floor and eliminate the engine doghouse. Maybe I can install some pedestal seats that swivel around!
I'm starting with a Heavy Duty Œ64, so I already have the beefy frame advantage you are looking for. It's officially rated for a 1-ton payload.
Once I get started on the project, I'll post my progress at vintage-vans.com.
  #5 (permalink)
Old 11-14-2011, 08:19 AM
Sounds like we are looking at very similar builds. I will keep you updated as well. I am still researching parts and design to meet my goals but it would be great to have another brain to bounce ideas off of. Have you ever built an EV before? I haven't myself but I work in the generator/UPS/Battery field so I am very familiar with inverters, DC power, wiring, etc.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
