crooked steering wheel, spot on alignment - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-11-2011, 03:02 PM
cbzdel cbzdel is offline
cbzdel is starting off with a positive reputation.
My steering wheel is off by about 5 clockwise. But the alignment is spot on, if I let go of the wheel it goes straight as an arrow and everything is straight on the suspension. Rather than spend the $75 for an alignment to straighten the steering wheel is there a way to adjust it myself. I remember about 10 years ago when I had my Jeep Cherokee I was able to adjust something on the front suspension and change steering wheel without messing up the wheel alignment. Can I do this on this truck at all?
Old 11-11-2011, 03:14 PM
Smokeispower's Avatar
Smokeispower Smokeispower is offline
Smokeispower is starting off with a positive reputation.
It's the relationship between the tierod ends and the Pitman arm on the steering box. So you need to loosen (lengthen) one tie rod end and tighten (shorten) the opposite side. This will maintain the same distance between the ends but move where the arm connects to the center link.
Or just live with it.
Old 11-11-2011, 03:23 PM
Gotcha, I will just live with until its time for new tires.. I think my Jeep Cherokee had an adjustable drag-link which I was able to move the steering wheel around by loosening or tightening..
Old 11-11-2011, 04:15 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
On Super Duties there'a an adjustment sleeve on the drag link that centers the steering wheel. This is the only pic I have that's close , you can barely see it in the upper left.
http://www.ford-trucks.com/forums/93...installed.html
Old 11-11-2011, 04:45 PM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Uhmmm, I don't really think this is going to work. If you lenghten one side and shorten the other All that is going to do is shift the tie rod to one side or the other, and that is only if you actually disconnect one tie rod end from the knuckle. If you dont disconnect one side all you are going to do is change toe in/out.
As the other fella said, he needs to adjust the drag link a bit to get his wheel centered. This does not affect alignment at all. Messing with the tie rod will if you don't know what you are doing.
Old 11-11-2011, 04:51 PM
Disgruntled Texan
The first guy is describing a way center the wheel on an IFS with rack and pinion steering, but even then I'd assume there's an adjustment on the steering link that goes into the pinion. But with the crossover steering on the SD where the tie rod and drag link connect through the passenger knuckle, adjusting the tie rod does squat except screw with your toe.
Old 11-11-2011, 04:58 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Attached is a parts explosion of your steering. The drag link (or center link) is labelled #4. You can turn the adjustment sleeve (#3) on the drag link to adjust the steering wheel position without having any effect on the alignment otherwise.
If you get under it and examine it, you'll see and it'll make sense.
Old 11-11-2011, 05:08 PM
Great! this sounds exactly what I did on my Jeep Cherokee!
Old 11-11-2011, 06:43 PM
You guys are right. Should have slid under my truck before answering, but it's cold out today. I was thinking of IFS and was wrong. Glad he didn't go and try it my way! Yes, drag link adjuster will do it. They should have done this when the alignment was done.
Old 11-11-2011, 11:35 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
It should also be mentioned that the above info is only true for 4x4 trucks. The smaller 4x2 trucks with IFS use a short/long drag link system similar to the OBS, and wheel centering can only be adjusted by resetting tow on each front wheel.
Jay
Old 06-20-2012, 02:52 PM
DevotedDad's Avatar
DevotedDad DevotedDad is offline
DevotedDad is gaining momentum as a positive member of FTE.
Is there a write-up on exactly how to do this for the drag link? My 2012 F250 SD's steering wheel sits at 11:00, though the alignment is spot-on. A minor thing, yet it drives me nuts!
Old 06-20-2012, 03:06 PM
Disgruntled Texan
You just pop open the level and turn the collar. Look at the threads, making the drag link shorter is what I would guess moves the wheel clockwise, but if that's wrong there's only one other option.
Old 06-20-2012, 03:11 PM
sddesigns's Avatar
sddesigns sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Quote:
Great write up here!
http://www.ford-trucks.com/forums/77...with-pics.html
Old 06-20-2012, 11:24 PM
DevotedDad's Avatar
Thanks, all - I'm going to fiddle with it this weekend.
DD
Align the steering wheel? jonrjen 6.7L Power Stroke Diesel 9 02-20-2015 08:26 PM
Steering Play - Is this adjustbale? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 3 11-21-2014 06:48 PM
1996 F150 Steering alignment fortyninebuick 1987 - 1996 F150 & Larger F-Series Trucks 0 11-06-2011 07:46 AM
straighten steering wheel NFLEagles1 1987 - 1996 F150 & Larger F-Series Trucks 15 10-25-2011 07:48 AM
Did ball joints. Truck wanders worse now. Steering issues also Bayer-Z28 1987 - 1996 F150 & Larger F-Series Trucks 15 05-07-2010 10:47 PM
Tags
450, adjustment, align, crooked, duty, econoline, exploded, f250, ford, missaligned, rods, steering, super, tie, tighten, truck, turning, view, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
