Ignition switch - 1 thru 6 terminals - Ford Truck Enthusiasts Forums
Old 11-11-2011, 12:20 AM
Myfreeford's Avatar
Myfreeford Myfreeford is offline
Myfreeford is starting off with a positive reputation.
Can someone tell me what connects to each terminal on the 1975 F250 ignition switch pictured below?
Looking at the back of the switch, the key would turn counterclockwise.
Thanks.
Old 11-11-2011, 07:09 AM
HeeHaw78's Avatar
HeeHaw78 HeeHaw78 is offline
HeeHaw78 is starting off with a positive reputation.
I would think your best bet would be to try and find another 75 and use a test light to figure out which wires do what in the different key positions. One or two of them is going to only have power when you are cranking on the motor. on my 78 there are two large yellow wires that have constant power. Then with the switch on all but 2 or 3 of them have power. Then there is a red one with a blue stripe on mine that had power when cranking on the motor. Hope this helps
Old 11-11-2011, 08:18 AM
OldStyle's Avatar
OldStyle OldStyle is offline
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
Hope this helps 1975 Ign Sw
Old 11-11-2011, 03:44 PM
01ferguson 01ferguson is offline
01ferguson is starting off with a positive reputation.
hey oldstyle, you wouldnt happen to have that same type diagram for a 79 switch, would you
Old 11-11-2011, 05:00 PM
OldStyle's Avatar
Rusty Roller
79 Ign Sw
Old 11-11-2011, 07:41 PM
thank you sir. good stuff! where do you get it from. i am currently rewiring my entire truck, with a "universal wiring harness" and am having some problems with it?
Old 11-11-2011, 08:06 PM
OldStyle's Avatar
Rusty Roller
These are from the factory shop manuals. They don't include the wiring schematics though; those are in a separate "wiring & vacuum" manual, which I don't have. I only have the '75 & '79 shop books....
If I see something I think is in the book I look it up, scan it, re-size, upload and post it.... Someday I will find them in *pdf but for now this works.
Old 11-11-2011, 08:14 PM
any idea where to locate the wiring and vacuum diagram? and thanks for the above
Old 11-11-2011, 08:47 PM
OldStyle's Avatar
Rusty Roller
Most dealers have a library and sometimes you can talk the parts manager to photo-copy a page for you, of course it helps if you know him..... What area are you having problems with?
Also .... http://fordification.net/tech/wiring.htm
Old 11-11-2011, 09:02 PM
thanks again oldstyle, just checked the switch, and it is ok. now if i can do the same for my headlight switch, and figure out the instrument cluster wiring, i should be in pretty good shape! thanks again
Old 05-08-2013, 11:23 PM
GoodiePop's Avatar
GoodiePop GoodiePop is offline
GoodiePop is starting off with a positive reputation.
1975 and '76 F250 Trucks
I am doing the same thing here. I have a brand new ignition switch purchased from LMC truck, and whomever their wiring engineer is, this person has one heck of a sense of humor. All of the wires in the plug that I bought are black.
I thought I was gonna die when I opened the package.
Here's what I did. I went Ford crazy. I bought the 2 F250's that I have, and now, just for grins, I want nothing but Ford keys hanging on my key rack here in the house, so when someone asks me for a key to something, I can tell them to get the Ford key.................."Alrighty then!"
I am installing a Ford truck ignition switch on my Onan generator and on my 1989 JCB 1400B backhoe. That will give me every vehicle that I have, "Powered By Ford", except mother's car, which is a Pontiac Grand Am.
I need to know what each spade is intended for on the back of my new switches, simply because I cannot lay down under the dash because of disability to read what is already there.
Any help?
Pictures to follow of my, "Ford Parking Only - All Others Will Be Towed", and, "Genuine Ford Parts Sold Here" signs in my driveway.
I just LOVE old Fords!!!
Old 05-09-2013, 12:07 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Any help?
LMC's engineer probably named Chen-Lee Wong and he lives in Shanghai.
I know what you're asking but there are diagrams/drawings in this thread with info on how to identify the terminals and test the switches. Don't ya see them????
Old 05-09-2013, 12:16 AM
GoodiePop's Avatar
I did see all of the pictures posted here, but what I don't see, is the wiring diagram/legend for the ignition switch that was originally pictured by MyFreeFord. I HATE that almost everything we buy nowadays is Made In China, especially when I'm trying to keep my American quality Ford trucks running!!!!!!
This is something that I need just shut up about right now before I get banned from here, squealing like a greased pig about crap that is made in you-know-where.
The pictures that I see here are for a different ignition switch. At least that's how I'm viewing the diagrams.
My name GoodiePop only means one thing. There's a soda pop and there's a Goodie Pop, and that Goodie Pop is a Miller Genuine Draft. I think you're smart enough to figure out the rest on your own ;O)
Old 05-09-2013, 12:21 AM
GoodiePop's Avatar
Nevermind. Reality just set in here. I see that the diagram I'm looking for is posted.
Old 05-09-2013, 01:21 PM
84espy 84espy is online now
84espy has a good reputation on FTE.84espy has a good reputation on FTE.
To the OP,
If you can swap the 75 to the 79. I did. It gives you a couple extra wires to play with and that sure comes in handy.
OldStyle, thanks for the drawing. Better than what I drew up
help- Wiring terminals PN needed. 74 F350 SCS 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-14-2015 04:53 PM
ignition switch abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 13 11-07-2014 09:19 AM
6v to 12v Ignition Confusion mbarrad 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 03-03-2012 10:55 PM
ignition switch on terminal alex crease 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-20-2004 12:52 AM
Tags
1966, 1974, 1975, 1978, 73, diagram, f100, f250, f600, ford, ignition, key, schematic, switch, terminal, terminals, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
