1990 bronco 5.8 no spark nightmare - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 11-10-2011, 09:22 PM
Rockstar Welder Rockstar Welder is offline
Rockstar Welder is starting off with a positive reputation.
Long story short, bought this 1990 bronco. Wouldnt start when i was looking at buying it. (helped me on the firm price he had) but it had spark. So rebuilt the upper end cuz head gaskit was leaking. Post rebuild still no start but had spark. Replaced all the relays, map senc. stator and computer. It started, ran for 10 mins(just had time to set timing) and just shut off like someone turned the key off. Checked for spark no spark. replaced coil and ICM. Started run for 10 mins and was running damn good an then shut down again. Checked for spark, No spark. Im out of ideas, please help me start to sleep at night again!
Old 11-11-2011, 12:12 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
rebuild or replace distributor in total, including new ICM.
Happy Motoring.
Old 11-11-2011, 12:24 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
Before doing anything stupid and expensive, like replacing the distributor, start with the simple things, you already pointed at something, the key-switch, then, since you say you have spark, you might be missing fuel, have you checked the fuel pressure?, have you checked the fuses?. Anyway, as the usual procedure with our trucks, get the codes first to see what does the ECU have to say.
Welcome to FTE btw!.
Old 11-11-2011, 06:18 AM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
Pull codes then check grounds by disassembling and seeing if the ground stud is loose in the fender at the battery pigtail and by the code checking connector. I am not sure but suspect the 92+ uses the black ICM.
Old 11-11-2011, 07:33 PM
i rebuilt the distributor, had to when i changed the pickup when it wouldnt start after the rebuild. I thought the pickup was bad so replaced it. At the same time i replaced the relays and the pigtails, the ICM (gray). Still no start, pull computer and it was fried(burnt fried) so replaceing the EEC it started. Thats when it started with the 10 min and stall. Replaced coil, and another ICM, ran and then 10 mins click stopped. I dont have a obd1 tester, so jumped plug and got no codes, but a buddy is loaning me one this wekkend ...just to double check ..b4hntn ill check thoughs grounds. Thanx guys, any ideas is one step closer to helping me at least getting to drive this BEAR..
Old 11-11-2011, 11:33 PM
Remove and replace the intake manifold to eliminate vacuum leak at manifold surface.
Old 11-13-2011, 05:28 PM
got codes...22, 81, 82, 84...81-84 i think i got fixed, bad vacuum line...22 is map but i replace that. Dont see why any of thoughs would cause the no spark. I cleaned the grounds. Still no spark.
Old 11-13-2011, 06:08 PM
I am certainly not an expert.
This is warm up , heat related then no spark. Rules out the ACT and ECT because they would just run badly.
Wild guess 1. I believe the 1990 had a push start, (grey ICM) circuit which means there is a resistor between the ICM and the computer somewhere.
Wild guess 2. PCM. If you replaced the computer with anything other than the same number it may cause problems. If you replaced it with a used one I may have the same time, temperature and vibration issues the original one had. See ECMTOGO.com for details. They might test yours free. I have had repaired or replaced my ECM, air bag, and overhead module temp/compass boards and mine is only a 94 and 17 years old. What electronics do you own that old that still work?
Old 11-13-2011, 10:54 PM
yep, gray one. tested resistor it seem to be in specs. I did replace the comp. Its a reman., i made sure the numbers were the same. I think im going to pull the distributor and replace the pickup again. I think i grabed the cheapest one i could at the time, hope thats not bitting me in the tailgate
Old 11-13-2011, 11:30 PM
Might be a feedback circuit that is causing the pickup to repeat fail due to the incompetence of some part that is not being replace during dist rebuild, see post #2, indicating to replace all parts of dist that are electrical.
Old 11-14-2011, 10:08 PM
yep, just going to replace the whole distributor....that way it should be pre-tested..thanx g_k50..ill keep u posted
Old 11-29-2013, 10:32 PM
5.8L V8 5.8L V8 is offline
5.8L V8 is starting off with a positive reputation.
Hey. Try testing the Fuel Relay. It has to have power run through it to feed the EEC. Which will then feed the ICM
Power if your ignition is working. There are some great write ups here to help http://easyautodiagnostics.com/index_ford_4.9L_5.0L_5.8L/index_of_articles_1.php.
Good luck.
Old 05-28-2015, 11:33 PM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
To me it sounds like a component or a connection should be getting hot, check wiring on the fender after it dies, at the coil connection and on the distributor. It's not likely but maybe the resistor is failing, test ohms after it shuts down maybe? You did use a dielectric grease on the TFI module when you installed it right? I seen something similar because ASE mechanic didn't. The TFI failed within the week.
'72 390 FE no spark from cap to plugs or low spark irishredcoat 1967 - 1972 F-100 & Larger F-Series Trucks 78 02-22-2016 04:30 PM
No spark issue-- actually, single spark..? exidor12 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-13-2015 07:34 AM
1990 ranger 2.9 no spark kenneybbbb Ranger & B-Series 6 03-28-2015 02:32 PM
Exhaust - One side hot, other cold, runs ROUGH! BRONC-OH Ranger & B-Series 4 02-06-2013 10:38 PM
76 460 no spark until key is released. 1bigtj Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 10-11-2010 02:35 PM
Tags
150, 1990, 49, 58, 93, 96, bronco, classic, coil, distributor, e150, ford, icm, spark, truck, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
