GoodRide Trailer Tires???
So IF ALL Trailer tires are made in China then why spend top $$ on them?? why not get the cheapest one in the proper load range and run them?
Supercab...
If you have a travel trailer/fifth wheel and one of the tires blows at speed, you would regret having the 'cheapest' tire available. The damage repair cost itself would justify getting the best tire you can find. If you have an equioment trailer and the only damage would be a bent fender, maybe it is worth the gamble. Having said that, seems like sometimes the good tires are blowing also. Having good tires, correct pressure and lots of extra weight capacity to me is the best insurance...
Joe
Supercab...
Joe
I agree with what Mud Doc had to say about buying the best tires available. I haul a triple axle freight trailer that uses up tires on a regular basis. I've run everything from High Runs to Goodyears and it seems the more I pay for a tire the longer it lasts. Certainly something to be said about paying for good quality.
I currently have a mix of Goodyears and Carlisles on the trailer and they seem to be the two best that I have dealt with.
I will also vouch for the damage done when a tire blows out on a camper. They usually rip the side of the trailer up pretty nasty and you had better have good trailer insurance to pay for repairs.
OK, How to trailer manufacturers get away with installing tires that aren't able to handle the load weight that THEY say the trailer can carry? I would think LAW SUITE for damage or injury.....
The TT we are buying will have ST22575R15LRD tires on it which are rated at 2540# each for a total of 10,160#
The trailer is said to be 8660# empty, BUT CAN be loaded up to 11,217# max-which is over 1000# over what the "D" rated tires are rated for.
The "E" rated tires are rated at 2830# each, 11,329# total, which when you look at it really isn't much of a buffer IF you really loaded it all up.
How do the manufacturers get away with legally????
Great advice
I tried that-no go-they said the factory doesn't carry the "E" rated ST22575R15 tires.
They are "trying" to discontinue the model that we want-we are kind of forcing them to build it for us-I am going to bide my time until we take delivery THEN let the factory have an earfull-probably won't get anywhere-but we really want this unit and there is nothing in a TT that can compaire.
2012 Forest River Sierra 323FK - Travel Trailer - RV Sales, RV Inventory, Massachusetts, Rhode Island RV Dealer, New Hampshire, CT
Execpt we ARE getting aluminum wheels!! we are ordering a brand spanking new one from a wholesaler in Ohio!
I'll probably remove the "D" rated tires when we get home, sell them on Craigslist, then buy the "E" rated ones.
remember there is a big difference between a name brand tire, like the Goodyear Marathon, that's made at a Goodyear owned factory in China and the Chinese made tire, with its own made up name, most often made in a government owned sweat shop of a factory.
Anyone know if Denmans are still made stateside? mine were put on in 2000 and still don't show dry rot.
I'm not surprised. Not at all. I have some of the newer tires of the 20 families in our group. The only two blow outs in our group in my lifetime were on newer campers that came factory equipped with garbage Chinese tires. One poor guy had multiple failures.
I inspect my tires every trip and keep them propery inflated, and out of the sun when stored.
i run the goodrides on my 7x14 enclosed work trailer. so does my father in law.
I would not run them on my 5th wheel. I run LT tires with highway tread on them.
The goodrides are cheap and seem to hold up decent. But hey for $85/piece mounted I can go through 2 of them before I could pay for ONE goodyear marathon.
#28
Very hard to find USA made trailer tires. If you have to use chinese maypops, keep an excellent watch on tire pressures and bulges, cracks or anything that doesn't look right. DO NOT USE LT TIRES ON A MULTIPLE AXLE TRAILER!!! Side wall construction is very different. Sharp turns tweak the sidewall on a multiple axle trailer. Go with a higher load range if you can. let's hope one day if we haulers keep the pressure on, we can bring this very important product back to the USA. Buy American whenever possible!!!!
#29
X2 on Maxxis.. The have a real good following. Maxxis are rated for 80 PSI Max, but your wheels could be rated for 75 PSI Max. I run my 225/75/15E's at 72 PSI. Never a problem in about 15000 miles so far.
"I ASK AGAIN: CAN anyone put their hands or eyes on a USA made ST22575R15LRE Trailer tire for me??"
To my knowledge there are none.
