1995 f250 xl 4x4 front brake job - Page 2 - Ford Truck Enthusiasts Forums
Old 11-27-2011, 10:09 AM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Question CAN THE HUB BE PLACE ON TO FAR UP THE AXLE SHAFT???
No the inner bearing sets/determines the distance, seal too but its the bearing as the hard limit.
Inner bearing outer race will only go into hub so far, can not be set to "deep".
Did you get and install the right bearings?
If you have the correct rotor and the correct bearings there would be no reason the hub/rotor assembly would go on to far.
Perhaps if you posted some pictures of the issue, the problem might become Readily apparent once we see it.
Old 11-27-2011, 02:51 PM
TX76F250 TX76F250 is offline
TX76F250 is starting off with a positive reputation.
+1
I even went as far as looking on Rockauto at the different rotors available to see if there was a variation, thinking that he might have the wrong rotor. Even with the wrong bearings, I don't think it could get that far off. It's a head-scratcher, that's for sure!
Old 11-27-2011, 08:57 PM
rjtlawncare rjtlawncare is offline
rjtlawncare is starting off with a positive reputation.
I will be working on it tomorrow and will put back on the heat shield to see if that gives me more clearance. If that does not solve the problem I will take a pic to show what the heck is going on with this truck. Thanks for the replies though I will post tomorrow. RJ
Old 11-28-2011, 01:22 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
It's definitely not the brake shield. You can put it together with or without the shield. I've done it both ways.
I think we need a pic. It's hard to say what the problem is without seeing it, but I'm guessing that as soon as we see a pic the problem will be apparent.
The depth of the rotor is controlled by the bearings. Sliding the axle shaft out far enough to get the snap rings on outside the hub is common but it won't affect the brakes at all.
You're not trying to put the caliper bracket on the wrong side of the mounting holes on the knuckle, are you?
Old 11-28-2011, 05:52 PM
Bankrupter Bankrupter is offline
Bankrupter is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by rjtlawncare View Post
Well this has been a night mare so far. This truck is very rusty and everything has been a B to get off. Got the rotor off and replaced (DURALAST GOLD), did the ball joints (MOOG), did the u-joints(DURLAST GOLD), New bearings (TIMKENS), New Rear Seal (MOOG). Got everything repacked and put back together. Torque the lock nuts to specs. Manual locker back on. AT THIS POINT I'M THINKING THE TRUCK GODS are going to let me get to the final steps of this job. WELL WHAT WOULD YOU KNOW THE CALIPER MOUNTING BRACKET WILL NOT GO BACK ON. IT IS TO CLOSE TO THE ROTOR IT NEEDS ABOUT AN INCH. I can line up the holes and get bolts in(NOT ALL THE WAY IN THOUGH) but the rotor will not move because it is riding on the bracket(wedge in). WHat the FU!@#%%. One thing that I didn't replace was the brake shield and now I'm thinking that quarter inch is the inch I need. WHAT DID I DO WRONG?? DOES IT MATTER IF THE SHIELD IS NOT PUT BACK ON??? DID I PLACE THE HUB ASSEMBLY ON TO FAR AND IF SO HOW FAR BACK IS IT SUPPOSED TO GO???? tHIS THING IS A NIGHTMARE PLEASE HELP!!!!!
You didn't seat the studs down enough.
Why I posted this in one of my replies before ... Look at the gap in the rotor to hub spin it and watch the gap change. Put a rim on and send it home with a impact gun if you have one. it will pull it all up tight and you can then get it all together.
Quote:
Originally Posted by Bankrupter View Post
Just take note to really seat the studs back down in the new rotor.
Other then this it could be wrong bearings ... Or what Andy said... If its the last one dont admit it :P...
Old 11-29-2011, 07:33 AM
Well it all went back together. This is what I did. First I took it apart all the way down to the axle shaft. Took the 5 bolts out of the axle shaft part, pulled it out and put back on the heat shield. Started the reassembly. Tightened the 5 bolts to 60 lbs, put on the hub, put in the front bearing and push the bearing in as far as I could by hand. Got the lock nut and put it on just to hold things in place. I then put the caliper backet on to see if it would fit. WHAT WOULD YOU KNOW IT FIT. So I torque that to 150lb. I when went ahead I torqued the locknut to 50lbs to set the bearings, I then back out the lock nut and retorqued to 30lbs. The next thing I did was back out the lock nut 150 degrees while I was rotating the hub. I then placed the lock washer on the key shaft making sure the nipple lined up with the lock nut. I had to move the lock nut clockwise to match up the nipple with the hole, so the rotation was not 150 degrees but now it was 130 degrees. I then put on the second lock nut and torqued to 65 lbs. I then spinned the hub to see if everything was good to go it sounded and look good. All though I did hear a sound like the rotor was hitting the shield so I push and pulled on the shield to try and bend it alittle, it stopped the scrapping noise so I moved on. Put the locker in and put the snap ring around the axle nose. Put the large O ring(snap ring) in, put the cap on, put new brake pad in and put wheel on. The wheel spins nice and free. Got in and started the girl up and pumped the brakes, felt nice and with good response. Got her back up on the jack to see if the wheel had any play. It's tight but the only thing that has me worried now is that the wheel is very hard to rotate. But I do remember it being hard to rotate before I started this project. IS THIS NORMAL????
TOday I do the driver side, hoping for the best. And thanks to all that replied to my post you guys are life saver. I will be doing back brake soon so look out for though posts I know I will need your help again.
Old 11-29-2011, 01:14 PM
andym's Avatar
No it's not. You either have a sticking caliper or a collapsed rubber brake line on that side. Both of those items should be replaced in pairs. If you don't you will probably have a pull to the opposite side and you'll be replacing pads on that side far more often.
Old 11-29-2011, 03:12 PM
No as andym pointed out it should not be hard to turn, pads should lightly drag but not prevent the wheel from freely rotating.
Remove the caliper see if the wheel freely rotates, if it does then its the caliper.
Inherent problem with new rotor and then new pads on a wheel that both where worn down.
The caliper had been functioning in position mid way or better in the extended position.
You push it all the way in and now are asking it to function in that position, piston near fully seated.
What I do is exercise the caliper to see if one will be serviceable yet.
With the caliper off and held in your hand (you have a big C clamp old brake pad). Working together with someone sitting in driver seat to work the pedal, have them slowly push the pedal down you stop the pistons (and helper) near the outer most travel with the clamp and flat bar worn pad doesn't matter what long as it works.
Now pedal is down pistons are all the way out, instruct helper let pedal up. You use clamp to push pistons back in all the way.
Repeat process several times (say 6 or 8 should do it) making the pistons move in and out full distance. Pedal clamp pedal clamp pedal clamp.....
(be sure not blow pistons out of caliper doing so)
After doing so more often then not it allows the calipers function normally again in the fresh "range of operation" expected, put there by the new full thickness rotors and new pads just installed. Pistons don't want to work there right off.
If the either one or both of the calipers will not fully "relax" after applying brakes replace it (you can see them relax if you watch and should see it happen). Should grab hard brakes applied and then release allow you spin wheel, pads drag yes but not hold. If not you will burn up your new pads/rotors quick.
Old 01-26-2013, 05:13 PM
Lindsay Kremhelmer Lindsay Kremhelmer is offline
Lindsay Kremhelmer is starting off with a positive reputation.
[quote=andym;11025146]Don't believe anything that you hear from an Autozone employee. Most of the time their experience comes from reading Haynes manuals and the only thing they've ever done to a vehicle is check the oil.
I agree with you on the AutoZone thing... I used to work there... I got fired for going above and beyond just checking the oil... Their whole 5 bolts deal is stupid... sorry... had to butt in... lol
looking to replace front rotors on my 4x4 97 F250HD Fastback460 1987 - 1996 F150 & Larger F-Series Trucks 1 11-13-2016 06:51 PM
brake rotors blueoval65 1987 - 1996 F150 & Larger F-Series Trucks 1 08-11-2016 10:18 AM
Front hub removal Help r59 1994.5 - 1997 7.3L Power Stroke Diesel 25 08-02-2016 01:20 PM
4x4 Front Rotors Newenglandfordjunkie Explorer, Sport Trac, Mountaineer & Aviator 2 08-13-2013 12:02 AM
1996 F250 4x4 auto locking hubs -- step-by-step instructions to remove them to replace rotors? Colorado F250 4X4 1987 - 1996 F150 & Larger F-Series Trucks 1 05-30-2011 12:54 PM
Tags
1995, 4x4, 58l, brake, brakes, f250, f250xl, f350, ford, front, greasing, hub, job, manual, remove, rotors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
