Transmission Problem Mazda 5 speed - Ford Truck Enthusiasts Forums
Old 11-10-2011, 12:55 AM
bhduck bhduck is offline
bhduck is starting off with a positive reputation.
When I back up and push the clutch in rear wheels lock up.
Took top off transmission and forks were worn. replaced with top from junk yard still have the same problem. Gears look great in Tranmission. Put in new clutch, flywheel and trans top with used forks still has the same problem.
When it first happen I was able to drive home just using 1st and 3rd gear. Now I have all the gears but it grinds when I shift to 2nd and will lock up when I back up. Stumped in FL.
1991 F150 4.9 124,000 miles 2 wheel drive
Old 11-10-2011, 08:06 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
I think, if it was me, the first thing I would do is to pull both rear brake drums to check that the shoe linings and shoe hardware are all intact.
If that is all good I would turn my attention to the differential.
Old 11-13-2011, 07:38 PM
Went to the Junk Yard In Orlando and bougth a used 5 Speed for $150. Works great.
Looking in the Old Transmission I still can not see a problem with the gears but somthing was not lining up right.
At least it fixed. I love the F150 easy to work on
M5R2 - Shift fork? tndallas 1987 - 1996 F150 & Larger F-Series Trucks 12 Today 12:42 AM
Help again greenmachine86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-09-2016 07:42 PM
m5r2 transmission problems catto95 1987 - 1996 F150 & Larger F-Series Trucks 3 02-04-2015 07:03 PM
'96 F150 Shift Fork Help buckthedog 1987 - 1996 F150 & Larger F-Series Trucks 11 07-25-2014 01:55 PM
m5od-r2 Reverse problems dawhits1 1987 - 1996 F150 & Larger F-Series Trucks 6 12-20-2012 10:07 AM
Tags
150, 1996, 5speed, f150, ford, mazda, problem, problems, slipping, speed, trans, transition, transmission, troubleshooting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
