Fan Belt Vibration 88 F250 7.3L - Ford Truck Enthusiasts Forums
Old 11-09-2011, 09:02 PM
LFDavidson LFDavidson is offline
LFDavidson is starting off with a positive reputation.
My belts on the Alternator to Fan and Power Steering Pump to Fan both have alot of vibration in them at idle. I changed all the belts tonight and they seem pretty tight but still vibrate alot. I can deflect them less than half an inch so not much slack. Looks like they move back and forth when its running about an inch. Is this pretty normal or do I need to try and get them tighter?
Thanks..
Old 11-09-2011, 09:17 PM
dieself250 dieself250 is offline
dieself250 is starting off with a positive reputation.
That sounds normal. The alt belt jumps the most. Carry extras you can throw a belt sometimes. Try to use premium belts , they stay on longer. Most of the flop is caused by the vaccum pump, they should smooth out with an increase in engine speed
Old 11-09-2011, 09:22 PM
monte97z's Avatar
monte97z monte97z is offline
monte97z is starting off with a positive reputation.
Mine do the same thing. Hope someone else chimes in but from what I understand it's normal for a diesel to do that
Old 11-10-2011, 06:13 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
it is due to the large span.
if there was an idler pulley in there, it would go away.
Old 11-10-2011, 07:21 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Mine to do that, they smooth out as RPM's are increased. Don't worry about it.
Make sure to have spare belts and hoses in the truck at all times and your set.
Old 03-23-2012, 10:47 AM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
Yeah the span is to long and the vacuum pump causes the jump. We bought this truck cheap several years ago because they couldn't hold the alt belt on it. I tried several things like new pulleys on alt and crankshaft but it didn't help. I finally fabricated an Idler pulley. Used the alterantor tensioner bracket bolt holes where it mounts to the water pump and mounted it there. Used a v-belt idler off a 70's something Ford Ac setup. This stopped the belt jump for aprox 4 years. I had it happen yesterday and the reason was the bearing went bad in the idler pressed new bearing in and put it back togather. Hopefully good for awhile. If anyone is interested I will be glad to email a picture of the Idler I made.
Old 03-23-2012, 02:02 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
Yeah, anything that "pulses" will cause that, and long spans amplify the effect. The vacuum pump has high then low resistance to turning, and the engine pulses as each cylinder fires. As RPM goes up, there is less time between pulses, and things seem to smooth out...
Old 03-23-2012, 07:22 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
x3,4,5,6 or whatever it is.....I have the same slop in my 7.3, and all three of my 6.9s(including my dad's 86)
Old 03-23-2012, 10:52 PM
whiteboyslo's Avatar
whiteboyslo whiteboyslo is online now
whiteboyslo is gaining momentum as a positive member of FTE.
Out of curiousity (warning: slightly OT), has anyone ever looked into installing the serpentine system off a 92-94 IDI to an older truck? Just wondering what would be involved........
Mike
Old 03-23-2012, 10:53 PM
Been done alot actually. Search it in the forum.
Old 03-25-2012, 12:06 PM
tecgod13 tecgod13 is online now
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Quote:
Please post up the picture, I'm sure a lot of us would be interested.
Old 03-25-2014, 07:45 PM
red97stroker's Avatar
red97stroker red97stroker is offline
red97stroker is starting off with a positive reputation.
Alternator belt jumping....
Can you post the pictures of this belt tension modification.Just replaced belt and don't want the new one to get ruined.
Old 03-25-2014, 08:29 PM
racer30's Avatar
racer30 racer30 is offline
racer30 is starting off with a positive reputation.
Mine on my MH are very long and flap real bad at idle but smooth out at cruise PM
V10 radiator fan FELL OFF while driving Wagion 1999 to 2016 Super Duty 15 05-17-2016 09:54 AM
Fan Belt baker51 Australia Chapter 2 10-12-2015 05:11 PM
'00 302 Engine Vibration TestPoint Explorer, Sport Trac, Mountaineer & Aviator 6 03-09-2015 07:00 AM
ac belt vibration 460 engine chizzy matt 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-01-2011 05:58 PM
290 cummins fan bracket Hokiewheeler Large Truck 3 07-04-2011 07:14 PM
Tags
1983, 1988, 73, 73l, 88, back, belt, belts, f250, fan, ford, idi, put, throwing, trucks, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
