1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
climate control system problems
Old 11-09-2011, 06:24 PM
jimnkaran's Avatar
jimnkaran
jimnkaran is offline
Unhappy climate control system problems
My 2005 F250 King Ranch, 4wd, 4 door heat and air system has quit. It occasionally has quit before but always came back on after a few stops and restarts. It has gone off now and does not seem to be going to start back up. What happens is it is working fine when I stop and shut the truck off, then the next time I get in and start it the heat and air does not come on. I checked with the Ford garage and they said the trucks computer will probably have to be replaced as that was a problem with the King Ranch. Anyone have any other ideas?? Thanks, Jim
Old 11-10-2011, 01:12 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Mine went out the same way on my '05 Lariat. They had to replace the head unit for the HVAC controls. I think it was about ~$400.
Old 11-11-2011, 09:44 AM
ccerniglia's Avatar
ccerniglia
ccerniglia is offline
This is more likely then the "computer" or PCM.
Old 11-11-2011, 09:55 AM
jimnkaran's Avatar
jimnkaran
control
Well, just like before I got in and started the truck and it is now working again. Last time it worked for over 6 months before it quit. Ford said that if it is working now they can not fix it, must be broken when I come in. Frustrating.
Old 11-11-2011, 10:02 AM
powerstroke72
I had the same situation with mine. Intermittent failures and then I got in one morning and it wasn't working. I drove straight to the dealership, blew the horn, and when the door opened, I drove right in. I pulled it into the garage, left it running, got the Service Manager, and he ordered it right then. I got the same story though.....couldn't do anything until it actually stopped working. I believe it has more to do with Ford tightening their belts when it comes to warranty replacements, than anything else.
RamblinAnne
13
04-22-2019 05:43 PM
Delawhere?
01-02-2012 02:06 PM
LACityFD
2004 - 2008 F150
11-26-2009 08:17 PM
murraydav
08-27-2008 08:35 AM
Mwachel
04-28-2006 04:32 PM
Quick Reply: climate control system problems
