5 to 6 spd manual transmission
Did the 99 V10 come with a ZF-5 transmission? What are you hoping to gain by doing this swap? I know on the diesel side, the final drive ratio in 5th compared to 6th on the different transmissions is not enough to make any difference. The ZF-6 has a granny gear that is great for getting started up to about 5 mph, but on the highway, the rpm's wont be any different.
ZF-5 was the 5 speed manual, which I believe they stopped using in 97 and the ZF-6 was the 6 speed manual introduced in 98 which was called the early 99 models.
I've dealt with some of you SO guys before. You're much better than the regular Army guys. You're almost tolerable
All kidding aside, Welcome to FTE and thanks for taking your turn standing watch over this great country.
If your goal is lower highway rpm's, gears are the way to go. If you like the transmission idea, look into this http://www.gearvendors.com/fdrive.html
One alternative to going through a regear would be to get taller tires to reduce your effective gear ratio.
For example stock my truck came with a 28" diameter tire with 3.55 gears I currently have 30"'s on and my effective ratio is 3.31 and if I get the 33"'s I want then I going to be sitting in the neighborhood of 3.01.
Hope this helps.
Hope this helps.
Thanks for everyone's input.
Just for giggles, if I wanted to upgrade my 5 to a 6, does anyone know what the transmission tag number would be to upgrade to?
All I can find so far is:
Engine: Year(s): Tag Number:
<table cellpadding="3" cellspacing="0" width="100%"><tbody><tr><td align="left" bgcolor="#D3D3D3" valign="top">6.8L / 415</td> <td class="style1" align="left" bgcolor="#D3D3D3" valign="top">2002-2003</td> <td class="style1" align="left" bgcolor="#D3D3D3" valign="top">ID 1C34-BD</td></tr></tbody></table>
Thanks all!
Thanks all!
