Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 11-09-2011, 03:36 PM
Nkelly's Avatar
Nkelly Nkelly is offline
Garage is empty, add now
Nkelly is gaining momentum as a positive member of FTE.Nkelly is gaining momentum as a positive member of FTE.
Next mod if you like
Now we can rip our bearings out and repack em,rather than throw the whole hub away and cost us another 6-700 bucks..
Rocket Sports Trucks - Take your truck to the extreme!
$1000 a side.
I bought 1 of these canopies yesty $ 4600
http://www.rocketsportstrucks.com.au/canopies.html
AND also in about a weeks time once i fit it i'll be able too show you aussie drivers a BIG improvement for our trucks
COMING SOON.
__________________
Bryan.
2005 FORD F250 7.3L, Maxxis BigHorns 35's,16x10 alloy rims,5"Procomp/Icon Vehicle Dynamics lift,AIH Delete,CCV,FRX,HPX, OCR,JW valve body,mag-hytec rear diff cover,wicked wheel,Garrett turbo outlet,F6 chip,Custom 4" to 5" exhaust,All from clay @ RiffRaff,BD big trans sump,Carpc got the ****,got a IPAD in the dash now
  #2 (permalink)
Old 01-30-2012, 04:19 AM
Nkelly's Avatar
New panhard bracket Drivers side Chassis
Click the image to open in full size.
Bracket on front diff cover
The components
Bits i dont need.
__________________
Bryan.
  #3 (permalink)
Old 01-30-2012, 04:35 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
who's pitman arm are you using and whats with the second bracket
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #4 (permalink)
Old 01-30-2012, 06:45 PM
Nkelly's Avatar
Quote:
Im using the drop pitman arm that airbagit sent me..
Which second bracket.
__________________
Bryan.
  #5 (permalink)
Old 01-30-2012, 09:51 PM
the gray one on the passenger side. Im assuming for the stock panhard rod. for us poor people who cant afford 2 air bag kits
__________________
Brian
  #6 (permalink)
Old 01-30-2012, 11:56 PM
Nkelly's Avatar
the one that is bolted to the front diff
the other one bolts onto the chassis and is designed for stock height up to 8" lift and YES with a stock panhard rod.
for us poor people who cant afford 2 airbag kits
Well if you didnt have 4 months off (slack f**k) and drove the concrete twuck urself,you could buy 1
__________________
Bryan.
  #7 (permalink)
Old 01-31-2012, 01:33 AM
Quote:
you have a valid point there my friend
I see now, the first pic has it all connected the second pic (which I thought was the spare) doesnt.
__________________
Brian
  #8 (permalink)
Old 01-31-2012, 02:07 AM
Nkelly's Avatar
OH i have first and second around the wrong way
Sue me.
__________________
Bryan.
  #9 (permalink)
Old 01-31-2012, 03:38 AM
Sue me.
My lawyers will be in touch
__________________
Brian
  #10 (permalink)
Old 02-01-2012, 06:35 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Gooseneck tow hitch in the tray.
Rocket Sports Trucks - $1150, comes with engineer's certification
Around triple the US price for the kit, although the US kit comes with a 2 5/16" ball while the Aussie kit is supplied with the Aussie 3" number.
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #11 (permalink)
Old 02-01-2012, 01:05 PM
Nkelly's Avatar
Ya reckon RPT are dear,im doing my injectors atm,rang around to get a price on rocker cover gaskets,because i would have to replace them.
RPT $ 217 per side - injector wiring loom $158 per side
Moparts $ 220 per side -injector wiring loom ?
Ethridge ford $ 420 per side -injector wiring loom ?
Yarra ranges ford (my local dealer) $585 per side- injector wiring loom ?
Asked clay,he said if they aint leaking use them again,because they are o-ringed.
__________________
Bryan.
  #12 (permalink)
Old 02-05-2012, 03:09 AM
2005 Ford F-250
How come you ba$tards aren't excited about my Rocket Sports Truck gooseneck hitch?
Gooseneck's not cool enough for ya?
__________________
  #13 (permalink)
Old 02-05-2012, 04:43 AM
Only if the engineer who signs the certificate is called Bruce
Then Im excited
__________________
Brian
  #14 (permalink)
Old 02-05-2012, 05:09 AM
2005 Ford F-250
You guys are all truck and no trailer !
__________________
  #15 (permalink)
Old 02-05-2012, 05:22 AM
Nkelly's Avatar
Oh dont worry im ALL truck and trailer bruvva.... *dribbles*
__________________
Bryan.
Tags
gooseneck, hitch, nj, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
