Of course I was talking about a shed load of horses under the bonnet of your F250 and nothing to use it on
__________________
Mods done: lots and lots of cheap mods
Mods NOT done: big oil, big exhaust (other than the tip), big brakes, DP tuner
Next mods: HPOP (big oil), big exhaust, 38R, DP tuner, stage 2 injectors
Was transmission upgrade in your bucket list of mod-money?
__________________
JW valve body for the 4R100 auto-trans on my truck. Ordered from RR last week. Planning to install at the tech-session 31/3. Man I hope it comes in time.
Also got the RR over-boost reg. I'm pretty sure that I've hit the overboost condition in the truck a couple of time and the RR over-boost reg should stop that happening - so more power going up hill under load and throttle. I'll fit that myself as soon as it comes!
__________________
So Clay can do just the hangers for the front ????
Can you use the shocks you have ????
__________________
Brian
03 F250 XLT LB Slowly working towards 500HP - In The Truck - 38R, F6, RR, aFe II, 4" turbo back, Gauges and some other stuff. -On the Bench250/100's, Terminator HPOP, Sage 1 cam, OEM pushrods, Fluidampr, ARP Head Studs, Comp 910's and counting
- cant wait until my motor blows so I can blame someone else - join the Australian Chapter here-Join Chapter
__________________
Brian
Bryan, can't believe you've gone back to leaf springs after all the linkages you've had on your truck.
I notice the Icon 3" system doesn't come with longer U bolts for the rear axle. If you end up needing a set let me know. I ordered Ruff Country 3" lift kit and got a set of really long U bolts which I didn't end up using. For me, once I'd removed the shortest stock leaf from the spring pack and inserted the higher blocks, the U bolts that were on there still did the job. The rear suspension is a lot plusher having removed the short leaves, which were about 1/2 an inch thick!
BTW, I haven't shelled out yet for the RST hitch (the gooseneck one). I figure if we get a bigger horse float I'll stick to the normal 4.5T towbar. At least that way if I end up selling the big float I have a larger market of buyers - i.e. all the Landcruiser (non-ute) drivers
__________________
2" pro comp springs + 3" hangers and 5" rear block.
5" lift
OK m8. Im with ya. Pretty much the same as Im looking at
__________________
Brian
