You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
So I just got my truck all back together, after a week of seating valves, and new gaskets... Now I am getting an air leak, it is coming out of the throttle rod that connects the butterfly venturies, I have heard from a couple of people this is common for the Motorcraft 2100's, because they don't have bushings like others do. I can't afford a new carb or anything like that. Is there a way to fix this? It is newly rebuilt and because of my massive missing problems, I couldn't catch on to it before.
1 other thing. I noticed when starting my truck, when turning it over- you can turn it nonstop and nothing will happen, the truck WILL NOT fire until you stop turning it over, this is a bit weird to me, anyone know why this happens?
P.S. I moved this thread here in hope of finding an answer (BII thread doesn't get answers often enough)
__________________ Live in Oregon? Click HERE to join the Oregon Chapter!
That start only after release of key from "START" position problem is usually because you haven't bypassed your ballast resistor with a wire from the starter solemoid directly to the coil.
What year, and what kind of ignition system did you say you have? (You didn't.) Is it the '84 B-Twice?
Notice the little "S" and "R" next to the ballast resistor? That's the "START" and "RUN" outputs from the ignition switch.
The "R" goes through the resistor. The resistor is there to reduce the average voltage output to the spark plugs. The spark doesn't have to be as "hot" while running, and it keeps the entire DuraSpark unit from running hot.
The "S" supplies a full +12 volts to create a hotter spark during the time the starter motor is lugging down the battery voltage. It helps to have a little hotter spark while starting.
My guess is that you don't have the wire from the "S" to the coil, the one that effectively "bypasses" the resistor. Make sense to you?
That "S" source can come from one of the small terminals on some Ford-type starter solenoids, from the ignition switch directly, or even from the starter motor.
I answered your carb question in your other thread in the B2 forum.
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......needs a new TK-5 trans, PM if you have one!
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
If the DuraSpark came from the factory, it would be there.
However, since you modded the B-Twice to add DuraSpark, it's possible that you may have missed adding that wire.
If you were to put a multi-meter (reading voltage) on the "BAT" side of the coil (other wire of the voltmeter to ground) what would the voltage be during "CRANK"? If it's next-to-nothing, there's your problem. If it's close to battery voltage, that's not your problem.
The engine WILL run normally, once started, right?
The 83-84 duraspark swap is plug and play, the 85 is more problematic and requires a ballast resistor to be added............Sure your B2 is not a 85?
As Marv says..............Start testing.
__________________
Dave
NO resistor is needed for 83-84 Ranger/B2 2.8 duraspark swap...........Check the diagram on the Rangerstation site.
__________________
Dave
Is that because the resistor is built into the harness, or is the design different to not use a resistor at all?
There's still something amiss when the truck won't start until you release the key from "START" to "RUN".
Pop
I followed the Rangerstation Duraspark swap for my 84, and no ballast resistor was needed per the instructions, it runs flawlessly. I think that resistor must go, and was only for the 85' yr models. Why... I have never researched, all I know is it WORKS!!
__________________
Dave
Well, that solves that issue. Still having a carb issue, I think.... It seems no matter what I do with this thing I can't ever have this head ache over with!
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
