Valve cover gasket ? - Ford Truck Enthusiasts Forums
Old 11-08-2011, 08:48 PM
teamgsxr teamgsxr is offline
teamgsxr is starting off with a positive reputation.
Is it possible to change the passenger side valve cover gasket on a 2003 f250 without tearing half the motor apart ?
I have a leak on the bottom rear corner. I washed the engine top and bottom and its starting to leak after 1000 miles out of that corner.
Thank you in advance.
Old 11-08-2011, 09:14 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
For more room...you'll have to pull the CAC (turbo to intercooler) tube, heater lines and glow plug controler. Much easier on the odd side (passenger) than the even (driver) side of the engine. Or at least IMHO.
Old 11-08-2011, 09:27 PM
bodabdan's Avatar
bodabdan bodabdan is offline
bodabdan has a good reputation on FTE.bodabdan has a good reputation on FTE.
I just had mine off for the first time. I found it very helpful to use a flex-head gear wrench to reach the ones closest to the evaporator housing. It's easier to get them from the bottom than it is from the top IMO. Your gaskets should be reusable, may just need to snug it a little.
And yes, definitely pull the CAC tube and wahtever else is in the way. You'll be glad you did.
Old 11-09-2011, 10:29 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Try just torquing it to spec. The gasket is reusable and very durable, so I doubt it is damaged.
Old 11-09-2011, 10:32 AM
This weekend I will loosing all the bolts and retorque them as you guys reccomend. I will give that a try first.
thanks again.
Blowing oil out of my breather cap AbandonedBronco Ford Inline Six, 200, 250, 4.9L / 300 13 02-19-2015 10:21 AM
Pushrod / lifter inspection cover leak 1986F150six Ford Inline Six, 200, 250, 4.9L / 300 2 08-21-2014 12:21 PM
Oil Leak Question 88 F250 7.3L LFDavidson Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 11-09-2011 05:43 PM
Rear Main Seal Leak... zman7125 Ranger & B-Series 16 01-03-2011 03:54 PM
390: odd oil leak near #4 cyl. Steve A FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 12-02-2004 11:31 PM
Tags
2001, 2003, 2004f250dieselvalvecovergaskets, 54, 68, cam, cover, f250, f350, ford, gasket, gaskets, leak, oil, shims, v10, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
