truck trying to start, ignition not engaged
11-19-2011, 12:03 PM
on
i have a 150 that is trying to start when we hook up the battery cable and the ignition is not being engaged,does anyone know what could b the problem???????
11-19-2011, 12:26 PM
on
Solenoid valve stuck closed?
11-19-2011, 12:43 PM
^^^ Most likely cause. Remove the little wire from the solenoid to eliminate a short or other problem but if it still tries to start then I'd replace the solenoid. You could try and tap it to see if you can get it loose but if it stuck once it's toast and on borrowed time.
11-19-2011, 12:54 PM
Jly154
02-12-2015 09:39 PM
RobertD123
05-03-2012 09:32 PM
jtl4482
04-21-2011 09:43 PM
FordBronco88
1978 - 1996 Big Bronco
09-02-2009 12:52 AM
76rustbucket
13
02-02-2004 07:45 PM
