300 inline mods thread
I figured I would start a mods thread just for fun. Anyone know of any, other than obvious, mods to improve power and economy. I for one heard of a 90's model with the 4.9 getting 22mpg. He ran the mazda 5 speed, not sure on the rear end size.. He had a free flowing true dual exhaust, electric fan conversion, k&n intake, blaster coil, timing advanced to 13 degrees, top of the line plugs and wires, and all new ignition and fuel components. I was wondering what else could be brought to the table. And does anyone have a link to the electric fan mod? And has anyone done true ram air?
As for electric fans....No real use for them...If its a simple DD...IMPO....More issues, problems, etc...Than what its actually gonna gain....
Modifications-Bolt Ons, etc...
-Hedman Headers-Carb'ed or EFI engines
-Dual Plane Offenhauser Intake Manifold-For Carb'ed engines
-Single Plane offenHauser Intake Manifold-For Carb'ed engines
-Cloyes Steel Timing Gears-Carb'ed or EFI engines
-MSD 6L Distribution Box-Carb'ed or EFI engines
-MSD (Or equivalent wires)
-MSD Coil-Carb'ed or EFI engines *Note-The Non-Carb'ed engines don't use the TFI module MSD Coil....The EFI engines otherwise, do....Watch the parts #'s...
-Side gapping the plugs (Controversy starts now...)Performance Unlimited 4-Wheel & Off Road Center - Hartford, Wisconsin - USA Technical Documents
Modifications-Internal....
-390 Pistons-Carb'ed/EFI engines *Note-They have the same wrist pin size, etc...
-351w Pistons-Carb'ed/EFI engines *Note-They have to be bushed...
-Aftermarket Camshafts-Carb'ed/EFI engines *Note-You'll need to make sure its computer friendly for the EFI engines...
-Port & Polish the head *Note-On the Carb'ed engines, leave the Intake runners somewhat rough (For better atomization..)
-1.7" Chevrolet Roller Rocker Arms *Note-Can be used in place of a camshaft, for cheapness, etc...
-Shave the head....*Note-You need some quench left....Remember, the engine is a low compression/high torque engine in factory trim...Shave it too far, you'll have a lot of clearance issues...
As for getting the best out of the 300 in factory trim....Do a good Tuneup..Period...Thats about it....Unless you go forced induction....Check out www.Ford-Six.com .....It's nothing but Inline engines there...
My friend did that to his 92 F250 and LOST MPG(was around 14 to 16 MPG then went to 10 to 12!)! Nothing else was changed to engine but exhaust. We think there must be some back pressure in the exhaust for the ECU to be happy controling the EGR system. Any thoughs about that?
Backpressure....I honestly haven't seen much good info out there on the matter...I do know in diesels, its a BAD things (The turbo'd versions at least)...
Sounds like your friend either got too tiny of a diameter pipe, or a restrictive muffler...Idk though...
There's some controversy over that...Some ppl says it causes ignition issues (Predetonation, etc) and some says it causes the burn to be more directed....Idk...Never have peronsally done it...Truck runs fine as is....
The ISSUE, is the fact that it makes PEAK torque @ 2,000 RPM's......Where most vehicles are just BEGINNING to breathe.....See what I mean?
Yes, gearing helps...But the issue is still there....It needs to be opened up in the rpm's a tad.....Hence...A camshaft swap....
And actually the Speed Density tuning, will allow for ~10% of a change....
Check into a Moates Quarterhorse tuner, or a Megasquirt II system....
And im still a little sketchy on downloading premade fuel and ignition maps.
