No power at the ignition
Just finished putting in a new starter and a new solenoid. When I was taking out the old starter, the cable must have hit the frame and sparked pretty good. Its all back together now and I have nothing at the ignition for power. no lights, no horn no radio nothing. When I touch the starter wire at the solenoid to the wire coming from the battery she cranks great. Did I connect the solenoid incorrectly, or did I blow a fuse somewhere. I checked all of the fuses in the fuse panel and they seem to be good. Confused
Everyone should put this in your favorites. EBSCOhost - world Its free for use. Just think how intelligent you can be now.
User ID--Bedford -------- Password--Library
There is loads of info there, all makes and years of vehicles. Just "CLICKY" on Auto Repair.
a more accurate and much faster way to check all the fuses would be to hook up a test light to a good ground inside the cab and then probe the top of each fuse. the fuses can look good but can be broken on the side and you can't see it. The link to the diagrams i gave will show fusible link locations.
93 turbo look at the fender mouted seilnoid the bottom right terminal large terminal it has yellow wires coming off of it to a bundle of fusiable links.... see at the top of my battery? see the blue heat shrink? well thats a fuse link when i burned out my ignition in a simallar situation ..... peel back the shielding and probe before and after the fuisbale link till you find one that is bad.... samething happen to me... a 3.00 link
Michael Schneider
1997 - 2003 F150
24
01-28-2018 11:47 AM
wporter4671
05-25-2009 09:42 PM
Jaxsyn1227
02-24-2007 02:24 PM
LoanStarCowboy
Electrical Systems/Wiring
12-03-2003 06:24 PM
