Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-08-2011, 04:10 PM
59PANEL 59PANEL is offline
Garage is empty, add now
59PANEL is starting off with a positive reputation.
59 Panel Suspension. Pro's and Con's
I recently picked up a 1959 ford panel(f100?). I believe these are on the same frame as an F100 truck, if not please tell me. I have been searching through the forums and reading about the different suspension swaps.
I have a few questions I would like to ask.
Is the crown vic front IFS too wide for the 59 panel application.
Other than the ford vs. chevy what are the cons of using the camaro subframe. The width seems pretty close.
I haven't looked into the volare swap yet and I can't afford the Mustang II kits.
Any info is greatly appreciated.
Tim
  #2 (permalink)
Old 11-08-2011, 07:50 PM
rcjccobra rcjccobra is offline
rcjccobra is starting off with a positive reputation.
As far as I know, the panel frames are the same as the F100. The CV front isn't too wide if you use negative offset wheels. I just installed a 2005 CV in my '57 panel. With the wheels I am using the outside of tire to outside of tire measured exactly the same. I actually bought a Nova front clip to install in mine first, but the big issue with it is you have to cut the frame off then build new front radiator mounts, etc. As far as the Volare, it's almost as bad as far as cutting up the frame and I've heard some say that parts are getting hard to get. I chose the CV because it's new and the parts will be around longer than I probably will. It's a very easy installation and everything is Factory designed and installed. You just install the unit.
  #3 (permalink)
Old 11-09-2011, 06:39 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
There have been many discussions on the benefits of various front end swaps on the forum. You probably can't use the search feature yet since your post count is still too low but you can get around that. Do a Google search for your topic and click on "advanced search". Near the bottom of the page is a blank where it ask for any certain site or domian. Enter www.ford-trucks.com You should be able to find all sorts of dialog on your topics of interest.
  #4 (permalink)
Old 11-09-2011, 07:22 PM
Quote:
Negative or positive offset? I thought positive was towards the outside of the wheel and negative toward the inside?
Thanks for the replies everyone!
Tim
  #5 (permalink)
Old 11-09-2011, 08:46 PM
Yes, negative is offset to the inside of the vehicle. Just like the new cars. The late model Mustang wheels work well on these.
  #6 (permalink)
Old 11-09-2011, 11:09 PM
KustomKidd's Avatar
KustomKidd KustomKidd is offline
KustomKidd is starting off with a positive reputation.
Just saying, I put a volare in my 59 using Bobs F100's expensive templates...I like it.
  #7 (permalink)
Old 11-09-2011, 11:24 PM
Quote:
How close was the width?
  #8 (permalink)
Old 11-10-2011, 07:07 AM
I think the Volarie will allow you to go lower.
  #9 (permalink)
Old 11-10-2011, 08:59 AM
KustomKidd's Avatar
Quote:
It's the same track width.
  #10 (permalink)
Old 11-10-2011, 05:40 PM
hawk1959's Avatar
hawk1959 hawk1959 is offline
RATROD58
1959 Ford F-100
hawk1959 is starting off with a positive reputation.
How about the Jaguar front end some guys are using them , i went to look for CV front but the place i went to didnt have any but they had the jaguar pretty cheap $140 bucks for the hole thing
Tags
1957, 59, con, ford, panel, pro, suspension, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
