Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-08-2011, 09:45 AM
leewiffen leewiffen is offline
Garage is empty, add now
leewiffen is starting off with a positive reputation.
Fridge suspension and steering
Hi Fellas
Well my fridge starts drives and stops now. It's registered and on the road, and now I know what needs to get better!!
It's sits on P235/R75/15 Tyres and has original springs, with one broken on the rear
The steering is incredibly wooly...about 5 or 6 inches travel before the wheels respond
The suspension ride is incredibly cranky and clunky.
My query is can I improve both things without huge expense? New steering box? Is that the reason for the wooly steering?
Upgrade the springs to a different tensile?
Thanks
Lee
  #2 (permalink)
Old 11-08-2011, 01:34 PM
windsor8689's Avatar
windsor8689 windsor8689 is offline
windsor8689 is starting off with a positive reputation.
You can jack up the front, jack stands under axle, take the wheels off for easy access.. turn your wheel back and forth. I did this to mine and found out I had hard spot in the steering.....i figured since its a solid axle it should be easy I will redo the whole front end. New King pin set,spring bushings,wheel bearings, tie rod ends, drag link. I took out the steering box/column and took a look inside mad sure I had no worn out worm gear..then put it back together then filled with grease. It took a couple weekends. You can fix 1 part at a time but you figure since your down there...... but for under 350 bucks I was Happy....
Or you can install IFS for example a mustang II or volare.....
It all depends on you, Are you gonna take corners like a racer, or its a grocery getter on the weekends...
__________________
ERIC
  #3 (permalink)
Old 11-09-2011, 06:48 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
The best way to go if you want "little" expense is to stay stock. First step is the shop manual for your truck. Second is one or more local parts places, preferable with people not afraid to look in the old paper catalogs.
Then you can go through the steering and suspension one item at a time. On the steering, check for loosness in kingpins / steering knuckles, wheel bearings, tie rod ends, drag link, and steering box. Get a helper to turn the wheel when you check things, the manual describes how and has some illustrations. Nothing is complicated, but sometimes you do need some brute force. On the suspension, look for a spring shop that can build up springs. Good springs can improve ride and handling. replace spring pins and bushings also when changing speings. Do not forget shocks, get good ones. Also inspect spring mounts, spring perches, and shackles. Cracks from years of fatigue and thin areas from rust can let these deflect too much and give squirlly handling.
But the biggest thing to keep in mind is that these trucks are over 50 years old and were designed as work vehicles to suit the expectations of that time. Steering will be somewhat slow (but fairly precise if everything is good and tight). you will feel just about every irregularity in the road, especially when you are empty (Loading things up to about 50% of load capacity really smooths things out). They will tend to want to go wide in turns, and you will have to crank the wheel way more than your late model car or truck when parking (normal in the non power steering era). And you will have to drive conservatively. The stock brakes actually work pretty well if you keep them adjusted and in good condition. You must have to have a strong leg and be familiar with your stopping distance. Avoid cheap brake linings and also those that claim very long life. Keeping all of this in mind is not a big deal after living with one of these for a while, and you can have fun and be safe at the same time.
  #4 (permalink)
Old 11-09-2011, 07:00 AM
You know 3414 that's the best bit of advice I've ever had on here...It's what I was thinking. I've already renewed all the stock drum brakes on the truck, and it's a real exciting and thoughtful drive...so much more interesting than driving any modern car! I'm in the UK so the roads are full of traffic, so you have to concentrate really hard. I bought the truck with a non stock engine, a 351 short block along with these big wheels and tyres so I'm trying to work with those, but I'm definitely going to get my head in that workshop manual. Many Thanks. Lee
  #5 (permalink)
Old 11-09-2011, 07:25 AM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
In Memoriam.....
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
You can adjust out SOME of the slop,via the steering box - BUT - if you get greedy and try to take too much out, you can accelerate wear to the box.It's a fine line.Also,make sure the steering box is filled with the proper molybdenum chassis grease, NOT the heavy oil that other year vehicles/years require.If you put in 90 wt. oil in the stock steering box, it will just run out.The grease installed at the factory dries out and hardens.
I was ready to rebuild my steering box till doing those two things.Now, I'm good for a few more years
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Entitled, self-absorbed kids - meh."
  #6 (permalink)
Old 11-09-2011, 06:22 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
I would echo being careful on the steering adjustment. The grease inside it has already given over 50 years of service. It deserves refreshing. There are pretty decent instuctions in the shop manual for tearing it down and checking it out. There is also a procedure for adjustment.
Your point in the need for thoughtfull driving is well taken. These trucks do not drive themselves. However, if properly maintained, they will respond predictably. It is just another part of their appeal for those of us who are desperately entangled!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
