2006 6.0 Glow Plug wiring diagram - Ford Truck Enthusiasts Forums
Old 11-08-2011, 07:50 AM
Blinke9 Blinke9 is offline
Blinke9 is starting off with a positive reputation.
Question 2006 6.0 Glow Plug wiring diagram
Good morning. Did a ton of reading on the glow plug system yesterday and did the OHM check last night. The wire colors on the diagrams I saw posted didn't match the wire colors on my truck. I disconnected the 4 pin plug right behing the alternator and got infinity on the red wire leading to the right bank glow plug harness. I have code P0637 and I want to correlate the red wire to the #3 glow plug circuit. Can anyone confirm that I'm on the right cylinder? Thanks for the help. All other pins on that plug read around 2.3 Ohms so i think I'm pretty close.
2006 F-350 6.0 Powerstroke
Old 11-08-2011, 02:47 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 11-08-2011, 06:53 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Hopefully you meant P0673, which is glow plug #3. Because P0637 is something completey different.
P0673 should be plug #3, which is second from the front, passenger side.
My schematic shows the wire color from the GPCM to the plug #3 to be Red/Lt Grn.
Is it possible the Red wire you checked had a Lt Grn stripe that you could not see?
Plug #8 is the solid Red wire.
The GPCM also has a Red wire that is from the ignition.
Some Glow plug info I found in the Service Manual Yahiko 6.0L Power Stroke Diesel 47 12-05-2014 05:54 PM
Wiring harness problem johnwassink 1999 - 2003 7.3L Power Stroke Diesel 12 05-13-2014 07:10 AM
6.0 solution now no start Tylor Reynolds 6.0L Power Stroke Diesel 17 04-25-2014 10:59 PM
Dead injector after new harness F350-6 1999 - 2003 7.3L Power Stroke Diesel 2 06-24-2012 09:32 PM
Help confirm glow plug issue santacruzf250 1999 - 2003 7.3L Power Stroke Diesel 3 04-29-2012 11:01 PM
Tags
2006, 60, change, dia, diagram, diagramformotor60ford, diesel, duty, f350, ford, glow, plug, plugs, super, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
