1970 ford crewcab restoration, wyoming.
Old 01-07-2014, 07:30 PM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
heated mirrors soon.
Will be using some late 90's mirrors with this truck. found some that are heated and really need this in cold country! old iron with a modern twist. My friend jason who helps me alot thinks i've gone off the deep end with the mirrors. but he wants to help, he's easily amused also!
  #62
Old 01-07-2014, 10:09 PM
1FastGambler's Avatar
1FastGambler
1FastGambler is offline
Outstanding job!!!
I love it & you will love it even more the first time you drive it!!
Cheers!
  #63
Old 01-07-2014, 10:40 PM
460 Crew's Avatar
460 Crew
460 Crew is offline
Great looking crew, all the upgrades are great!
  #64
Old 01-09-2014, 07:14 PM
wyoming4x4's Avatar
wyoming4x4
thanks from wyoming!
hopefully the upgrades will come to a end!
  #65
Old 09-04-2014, 02:42 PM
wyoming4x4's Avatar
wyoming4x4
Getting closer to completion.
Fast 2.0 fuel injection installed and running! New 3.0 fox racing shocks. All new shock supports and related brackets.3.0 14" frt and 3.0 12" rear. Few more items to be completed. Working hydro boost brakes, 4 wheel disc. Getting hoses and fittings in soon.
  #66
Old 09-04-2014, 04:43 PM
1FastGambler
Pictures man!!
  #67
Old 09-04-2014, 05:17 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
Post em pics of the new goodies can't trade us like that. Glad to see your still working on the crew cab.
  #68
Old 10-20-2014, 02:39 PM
wyoming4x4's Avatar
wyoming4x4
1970 crewcab 4x4 fuel injected!
Been awhile since checking in. 70crew with fast fuel injection. Runs great, but. Their was some operator errors. Ohms on spark plug wires will give electrical noise. Need to verify your ohms on wires, fast has guidelines you need to follow! Wire power to batteries and not to solenoid then to battery, possible electrical noise issue! Finishing up on interior and noise dreading in cab!
[I]70crew 4wd, aluminum bed with lots of upgrades. 285/70/16" tires. Daily driver performance tow rig.
Aspens are falling, love the fall colors!
  #69
Old 10-20-2014, 02:50 PM
wyoming4x4's Avatar
wyoming4x4
Fast fuel injection and fox racing shocks 3.0
  #70
Old 10-20-2014, 02:53 PM
wyoming4x4's Avatar
wyoming4x4
Crew parking only! 79 crew and my 70 crew!
  #71
Old 10-20-2014, 03:03 PM
67nukeford's Avatar
67nukeford
67nukeford is offline
Truck looks beautiful!! Hey, I really like the look of those mirrors, might be something to think about for my 67. How was it setting up that fuel injection, been thinking about going that route also.
  #72
Old 10-20-2014, 04:10 PM
wyoming4x4's Avatar
wyoming4x4
Fuel injection not hard. Tedious and read instructions carefully! Then read them over again. I did the ignition and distributor also. Expensive! But everything is built to work together! If parts and plug wires in question could cause electrical noise, it happened with my accel wires and had to ohm wires for correct resistance. Fuel tank making all the ports in factory tank. Not hard but tedious. I built me a 40gal aluminum fuel tank in frame in back. Had to move a crossmember in back of frame to make this happen boxed frame at end of frame also.
Custom aluminum 42gal. Tank in frame. Had to move crossmember to make happen.
  #73
Old 10-20-2014, 05:01 PM
crazed87bronco
Damn your putting the finishing touches up on it. Turned out great glad you went with a v8 gasser. I'm getting tired of seeing every crew cab with diesel swaps lately. How's that link suspension feel in the front? I'm wishing I held off and spend the extra bucks on a set of fox 3.0's myself. But I never did a link suspension before so I didn't want to screw it up. Got any underside pics showing the suspension snd some of what interior you have in it so far? I really need to start back on my crew but relocating took up my whole summer so it's been dead in the water for awhile now. Hope to get something done to it before end of the year once the funds get back on track. The flatbed and body color really make it a stylish tow rig. Does that Fast setup make it feel like a modern day v8?
  #74
Old 10-20-2014, 05:46 PM
wyoming4x4's Avatar
wyoming4x4
Mirrors not hard make shims. Heavy thick rubber gasket 1/2". Belt sander about 3/8" top and about 1/16 btm. They actually bolt up nice to can on the arm that goes through outer body to inside. Measure 50 times cut once.
Taper shim for mirrors.
  #75
Old 10-20-2014, 05:53 PM
wyoming4x4's Avatar
wyoming4x4
Fuel injection and. Cold weather. Nice!
Been in the 20's and 30's temps and she starts nice. Still getting her tuned in. Engine still new. Haven't towed anything heavy yet, soon!
Quick Reply: 1970 ford crewcab restoration, wyoming.
