1970 ford crewcab restoration, wyoming. - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 01-07-2014, 08:30 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
heated mirrors soon.
Will be using some late 90's mirrors with this truck. found some that are heated and really need this in cold country! old iron with a modern twist. My friend jason who helps me alot thinks i've gone off the deep end with the mirrors. but he wants to help, he's easily amused also!
  #62
Old 01-07-2014, 11:09 PM
1FastGambler 1FastGambler is offline
1FastGambler is starting off with a positive reputation.
Outstanding job!!!
I love it & you will love it even more the first time you drive it!!
Cheers!
  #63
Old 01-07-2014, 11:40 PM
460 Crew's Avatar
460 Crew 460 Crew is offline
460 Crew is starting off with a positive reputation.
Great looking crew, all the upgrades are great!
  #64
Old 01-09-2014, 08:14 PM
wyoming4x4's Avatar
thanks from wyoming!
hopefully the upgrades will come to a end!
  #65
Old 09-04-2014, 03:42 PM
wyoming4x4's Avatar
Getting closer to completion.
Fast 2.0 fuel injection installed and running! New 3.0 fox racing shocks. All new shock supports and related brackets.3.0 14" frt and 3.0 12" rear. Few more items to be completed. Working hydro boost brakes, 4 wheel disc. Getting hoses and fittings in soon.
  #66
Old 09-04-2014, 05:43 PM
Pictures man!!
  #67
Old 09-04-2014, 06:17 PM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Post em pics of the new goodies can't trade us like that. Glad to see your still working on the crew cab.
  #68
Old 10-20-2014, 03:39 PM
wyoming4x4's Avatar
1970 crewcab 4x4 fuel injected!
Been awhile since checking in. 70crew with fast fuel injection. Runs great, but. Their was some operator errors. Ohms on spark plug wires will give electrical noise. Need to verify your ohms on wires, fast has guidelines you need to follow! Wire power to batteries and not to solenoid then to battery, possible electrical noise issue! Finishing up on interior and noise dreading in cab!
[I]70crew 4wd, aluminum bed with lots of upgrades. 285/70/16" tires. Daily driver performance tow rig.
Aspens are falling, love the fall colors!
  #69
Old 10-20-2014, 03:50 PM
wyoming4x4's Avatar
Fast fuel injection and fox racing shocks 3.0
  #70
Old 10-20-2014, 03:53 PM
wyoming4x4's Avatar
Crew parking only! 79 crew and my 70 crew!
  #71
Old 10-20-2014, 04:03 PM
67nukeford's Avatar
67nukeford 67nukeford is online now
Nebraska Chapter LDR
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Truck looks beautiful!! Hey, I really like the look of those mirrors, might be something to think about for my 67. How was it setting up that fuel injection, been thinking about going that route also.
  #72
Old 10-20-2014, 05:10 PM
wyoming4x4's Avatar
Quote:
Fuel injection not hard. Tedious and read instructions carefully! Then read them over again. I did the ignition and distributor also. Expensive! But everything is built to work together! If parts and plug wires in question could cause electrical noise, it happened with my accel wires and had to ohm wires for correct resistance. Fuel tank making all the ports in factory tank. Not hard but tedious. I built me a 40gal aluminum fuel tank in frame in back. Had to move a crossmember in back of frame to make this happen boxed frame at end of frame also.
Custom aluminum 42gal. Tank in frame. Had to move crossmember to make happen.
  #73
Old 10-20-2014, 06:01 PM
Damn your putting the finishing touches up on it. Turned out great glad you went with a v8 gasser. I'm getting tired of seeing every crew cab with diesel swaps lately. How's that link suspension feel in the front? I'm wishing I held off and spend the extra bucks on a set of fox 3.0's myself. But I never did a link suspension before so I didn't want to screw it up. Got any underside pics showing the suspension snd some of what interior you have in it so far? I really need to start back on my crew but relocating took up my whole summer so it's been dead in the water for awhile now. Hope to get something done to it before end of the year once the funds get back on track. The flatbed and body color really make it a stylish tow rig. Does that Fast setup make it feel like a modern day v8?
  #74
Old 10-20-2014, 06:46 PM
wyoming4x4's Avatar
Mirrors not hard make shims. Heavy thick rubber gasket 1/2". Belt sander about 3/8" top and about 1/16 btm. They actually bolt up nice to can on the arm that goes through outer body to inside. Measure 50 times cut once.
Taper shim for mirrors.
  #75
Old 10-20-2014, 06:53 PM
wyoming4x4's Avatar
Fuel injection and. Cold weather. Nice!
Been in the 20's and 30's temps and she starts nice. Still getting her tuned in. Engine still new. Haven't towed anything heavy yet, soon!
Looking for a great auto body shop in Billings to paint my '75 highboy. Wyoming1975F2504x4 Montana Chapter 2 01-11-2015 12:12 AM
EZ-efi 2.0 CJ 400 ford. install! wyoming4x4 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 18 02-16-2014 09:36 PM
aluminum flat bed on old iron. wyoming4x4 1967 - 1972 F-100 & Larger F-Series Trucks 11 10-19-2013 01:20 AM
64" leaf spring or link, 1970 ford wyoming4x4 1967 - 1972 F-100 & Larger F-Series Trucks 5 01-04-2013 10:04 PM
LMC cab mounts, not happy! wyoming4x4 1967 - 1972 F-100 & Larger F-Series Trucks 15 12-10-2010 09:47 AM
Tags
1970, 1979, antique, cab, crew, crewcab, doors, ford, parts, restorations, restore, sale, truck, trucks, wyoming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
