1970 ford crewcab restoration, wyoming.
#136
Hello highntight. As you can see I photos front core support shaved down. One thing I haven't done yet is do a spring loaded version at pins instead of washers! It's on the list of things to be done! Hood hinges are normal but I had to build up about 3/8" of glass. Also have a metal plate inside to help support glass. Everything seems to work well! Only other upgrade is maybe buildup glass under hood at front pins! Radiator is from mid 80's Ford F-250.
#138
#140
Hood upgrade!
Www.autofab.com builds the hood! You will probably have to make some mods to fit your truck correctly! Not a bolt on and go situation! Their are always mods! One thing I noticed is when driving in the rain the wind helps clean the windshield better! Like the visibility issues with the lowered hood also!
#141
#142
Ride quality 70 crew!
I have went to a lot of trouble and expense to get this truck lighter and ride nice! Upgrading to longer leafs from super duty 2011 was a awesome upgrade! I highly reccomend this for these ole trucks! 2011 leafs are 66.5" long. Measure 100 times and drill once! I have since upgraded to carli suspension pre runner leafs and it just got better! Did do a shackle flip on rear with the 2011 rear hangars and shackle! Older hangars with 3" wide leafs will not fit! Have to use newer hangars and shackle!
#143
Super duty leafs!
Bought a set of factory super duty leafs from 3/4 ton. Works nice! Had to move some stuff Round to get right stance but it's just a matter of drilling holes and these frames drill not to bad! Used leafs cost me $350 for my experiment!
This is original stance with 2" blocks.
#144
#146
I dont know how fancy you are going with your head liner... But I thought I would toss up a couple pictures of mine I just finished in my crew. I'm about 100 buck or less into it. I'm just right below you in salt lake city and bought it from laird plastics a local slc place. 1/8" abs plastic, Took a heat gun to it and molded in quiet nicely.
Don't know if its a route that you were thinking, but its an option... No painting, no cloth, no droop...
#147
Nice! I like! Simple setup!
#148
Lighting is nice!
#149
Been thinking the same thing.... My little beater s10 doesnt have any cab lights and it drives me crazy, But I dont want to fix it right now ether... Lol I hope its like the dash lights... When they go out I look for a bigger bump them the one that made the go out, lol And sure a s... they always come back on...
Sent pm about the headliner...
