body lift problems
body lift problems
so i was doing the cab part of the body lift and i snapped the bolt that is in the middle of the 3 on both sides...not to sure what to do about getting the bottom of the bolt out. does that mount seperate between the cab mount. also my radiator mount is rotted out so im also not sure what to do with that either since even if i did put the spacer in it wouldnt be holding anything to lift the truck. any advice would be appreciated.
thanks
thanks
I can't quite picture in my head which bolts you snapped.... if you could clarify that, then it would help. As for the radiator support, mine was so rotted out that I would have been in the same position as you when I put my lift in but I had a brand new support put in my truck before I did my lift so I didn't have any issues with that. I'd say if you want to get by on the cheap side then weld some metal in there that can rest on top of the spacer.
Received 3,103 Likes
on
I still don't understand all of the hatred towards body lifts... I installed my 3" with minimal problems and have had NO problems after lifting the truck. If it's done properly, then the truck will be fine. Mine is.... and get this.. the body hasn't slid off of the frame yet..
I understand in his situation, not having a decent support for the front two body lift spacers. However I had my support replaced, and everywhere the spacers went were underneath solid metal and my bolts were properly torqued down, etc. You can only say so much about body lifts until you actually put one in YOUR own vehicle. (I'm not really saying you should) Just that people around here tend to go along with everybody else's opinions on body lifts based on some story that their uncle's friend's brother's friend got into an accident and his body separated from the frame... etc........
I dont get the whole "40s on a half ton"
And you all know how i feel about body lift anyway.
Unless its a mall crawler, your going to have to upgrade the axles to 1 tons to run 40s without breaking anytime your off the pavement.
If you must screw up your truck with body lift, Replace the core support and remove the broken bolt and install new hardware. With body lift I hope your not thin skinned, becasue everyone laughs at body lift.
No, Chris, people like you laugh at body lifts. Remember us teenagers are "stupid and inexperienced" and we all like to "F#$@ up our trucks". I honestly could care less about anybody's opinions on body lifts. Mine turned out the way I wanted it to, and it was done right. That's all I have to say.
Easy there killer. I am not attacking anyone, just stating that body lift does not accomplish any real lift. it has been proven to be the most unsafe way to lift a truck and is frowned upon by hard core off road groups.
I dont care what you do with YOUR truck, that the beauty of it being yours, not mine.
Glad your worked out for you, but you will never find body lift on my rigs, i spend a little extra money and lift it what I CONSIDER to the the right way.
