EGR problems 1979 Bronco 460
We are finishing up a long project restoring a 1979 Bronco aND CONCLUDING A 460 SWAP. tHE PROBLEM WE ARE RUNNING INTO IS THE EDELBROCK 3766 INTAKE MANIFILD NOT LINING UP WITH THE STOCK 460 EGR PLATE FOR THAT YEAR (EGR PALTE HAS A LONG TRNECH WHERE AS THE 3766 HAS A SHORTER egr SHOULDER RESULTING IN ESCAPING egr GAS IN THE REAR OF THE INTAKE. hELP?
You need the Edelbrock Steel adapter plate to protect the aluminum from exhaust gasses, and the 3898 gasket. (cut out the cloverleaf web leaving only the front to rear divider)
http://www.jegs.com/InstallationInst...0/350-3766.pdf
You need the thin steel spacer to keep the exhaust gas from eating up the top of the manifold.
I linked the instructions.
Scroll down and look at figure 2.
The stack looks like this.
Carb
Thick Black Insulator
Ford EGR plate
Ford EGR gasket
Edelbrock steel shim
Edelbrock 3898 gasket
Edelbrock aluminum intake manifold
Locktite the carb studs with at least 1" sticking out of the manifold.
Use thin washers and Nyloc nuts to hold the carb down.
I like to use high temp aluminum spray paint or Coppercoat on both sides of the steel EGR plate.
(or it will come loose and burn out at the 'ear' of the EGR spacer)
Trust me...
Put some anti-seize on both sides of the EGR plate lower gasket if it's the perforated
metal one like the FelPro 60003 and you intend to reuse it..
DON'T use anti-seize on the pink composite genuine Ford E8TZ-9447-A / CG-536-B Motorcraft under plate gasket.
Hope this helps.
Carb
Ford EGR plate
Ford EGR gasket
Trust me...
Hope this helps.
My truck has the EGR to meet state emissions.
NOX is too high without it.
My choke was not fully opening for a week and the EGR valve and plate got all tarred up.
I had it all apart last week for a through cleaning.
It's pretty fresh in my mind, so ask away if you have any questions.
I think once you get the 3898 gasket and the steel plate you will see how it all fits.
...As I tried to describe above.
Remember what I said about cutting the right and left web from the 3898 gasket.
If not, it just gets sucked into the engine, and goes???
bullnose1985
16
10-15-2017 03:04 PM
santeeford
11-12-2012 12:52 PM
