7.3 quits running while driving - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-07-2011, 12:41 PM
quadm1 quadm1 is offline
quadm1 is starting off with a positive reputation.
My 2002 Superduty 7.3 runs great at 240,000 miles. Lately the engine will quit running while driving down the road. When this happens it will not start until it sits for one to two hours.
Old 11-07-2011, 01:02 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
When it dies and you go to restart, does the tach move while cranking?
Old 11-07-2011, 01:20 PM
That is something I have not looked at, all other lights go on and off including glow plug light.
Old 11-07-2011, 01:41 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
CPS most likely, but start with replacing fuel filer and checking if the fuel bowl fills up well
Old 11-07-2011, 08:28 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
One, fuel filter in the tank is plugged. Two: electric fuel pump is going bad. Three: fuel filter on top of motor is clogged. Four: HPfuel pump is going south. I had the same problem with my 99 7.3 at 265K miles, it was both the first two things listed causing the problem. It will run bad when the oil gets dirty and the oil filter starts to get plugged too, this reduces the oil pressure to the HP fuel pump causing a fuel pressure loss at the injectors.
Old 11-07-2011, 08:32 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 11-07-2011, 10:47 PM
Tailgate77478 Tailgate77478 is offline
Tailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud of
Sounds just like a CPS. But curious...how long "down the road" before it quits? In other words, I'm curious if it's starting and running OK while cold, and once it starts to get warm it quits (say, 3-5 minutes after starting).
How far down the road are we talking?
Old 11-08-2011, 01:31 AM
4inchlovin's Avatar
4inchlovin 4inchlovin is offline
4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of
More then likely the CPS (Cam Positioning Senor)... Takes about 5 min to replace
Heres a link for you to replace it!
Welcome to guzzle's CPS R&R Web Page<
Old 11-08-2011, 08:02 AM
I have repaced the CPS, there are no codes when it dies. There is really no given amount of drive time. It will happen randomly while driving as short as five miles down the road or I have driven a forty mile round trip and it did not die. I have left it idle for hours and it will not die. This has been going on for a year, so I do not drive it much anymore. It is time to get it back on the road. Dealer is lost and wants to start changing out parts. Seems like most responses other than CPS which was replaced a few weeks back are fuel filter related.
Old 11-08-2011, 08:09 AM
When you drive it, at what point does it die ? Mine ran fine until you put your foot into it and upped the fuel demand. That's when it ran short of fuel, creating an air bubble in the lines, that leads to the engine killing. Just like a human, it only takes a small air bubble in the veins (fuel lines) of a diesel to kill the engine. Starting it and letting it idle in the driveway, it would run all day. But the minute you started down the road and rev'd it up past 2000-2500, it would quit. We dropped the fuel tank and the stock filter assembly in the tank was falling apart. I completely removed this, replacing it with a short piece of fuel line and a brass "T" at the bottom, about a 1/2" off the tank bottom. Also wrapped that with plastic window screen to keep any larger trash out. I then installed an inline fuel filter/water separator (spin on)mounted to the frame just before the electric fuel pump. A few weeks later the electric pump went south (on a bumpy road) and I replaced it. No problems since.
Old 11-08-2011, 11:32 AM
Steve_250's Avatar
Steve_250 Steve_250 is offline
Steve_250 is gaining momentum as a positive member of FTE.Steve_250 is gaining momentum as a positive member of FTE.
Does it buck while driving?
Have you removed the electric plug for the ICP?
Is there an oil film in it?
Check this thread, is this the issue?
http://www.ford-trucks.com/forums/11...need-help.html
Old 11-08-2011, 12:23 PM
No bucking engine just dies and will not start for an hour or two. The problem does not seem to happen in cold weather. I do not believe it is RPM related (2000 - 2500 rpm) although it maybe accelerator related.
Old 11-08-2011, 01:17 PM
snakebite100 snakebite100 is offline
snakebite100 is starting off with a positive reputation.
Sounds close to my problem as well. I have changed the fuel pickup and filter, but still dies at about 30 miles of highway driving, but mine bucks slightly at idle and low RPM. It acts as if it runs out of fuel... White smoke and coughing, power dropping out ect. After cooling down 30 to 45 minutes, I can go 30-ish miles again.
Old 11-08-2011, 01:20 PM
Steve_250's Avatar
Snakebite, sure sounds like a CPS issue.
Pretty much 100% of them act just like that.
Dealer part is about $17 bucks.
Look on Guzzle's site for easy instructions.
Old 11-08-2011, 01:27 PM
I changed it once... Um... bout 100k miles ago. Think it has gone bad again?
2003 F250 7.3 cruise,radio and door locks baerpath 1999 to 2016 Super Duty 2 12-27-2015 03:48 PM
1995 7.3 engine just quits while driving landshark95 1994.5 - 1997 7.3L Power Stroke Diesel 14 05-07-2015 01:38 PM
2000 F350 runs short time and quits Bowrookee 1999 to 2016 Super Duty 0 03-24-2015 03:54 PM
Fuel Pressure BobbyB 1994.5 - 1997 7.3L Power Stroke Diesel 6 11-26-2014 09:14 AM
7.3 problems 95f3507.3 1994.5 - 1997 7.3L Power Stroke Diesel 9 05-28-2014 09:39 PM
Tags
2002, 2003, 73, air, bad, bubbles, cps, die, diesel, driving, ford, makes, oil, quits, run, running, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
