Ford Ranger A/C Vacuum Control Lines - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-07-2011, 12:01 PM
hhubred hhubred is offline
hhubred is starting off with a positive reputation.
Hi All, I recently replaced my heater core in 2000 Ranger and while working uder the hood, the grey vacuum line that leads to the interior of the truck browke . For the life of me I can't find where the other end is.
Does anyone have an Idea?
It one of 2 lines that lead from the engine compartment into the cab to control the A/C and Heat and its Grey in color.
Old 11-07-2011, 12:20 PM
harley9701 harley9701 is offline
harley9701 is starting off with a positive reputation.
gray vacuum hose.
The gray vacuum hose is connected to the heater control valve. If it broke inside look at the white vacuum hose going to the recirculation door, it could be spliced off that hose.
Old 11-07-2011, 12:30 PM
Thanks harley9701. Its broken outside in the engine compartment. It is connected to a modular splice leading into the cab located on the firewall and under the AC Condensor and fan. Im looking for were it went on the engine side.
Harley HarleyP 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-02-2014 08:44 AM
Grey Vacuum line strokingbeast 1999 - 2003 7.3L Power Stroke Diesel 9 01-10-2011 02:26 AM
small grey vaccum hose Randy777 6.0L Power Stroke Diesel 19 06-07-2010 11:21 PM
A/C & heater vacuum line problems jennkent5454 1997 - 2003 F150 5 01-26-2010 01:46 PM
Ideas for tracking vacuum leak? Pocket 1999 - 2003 7.3L Power Stroke Diesel 12 07-04-2008 05:19 PM
Tags
2004, ac, control, ford, heater, hose, line, lines, ment, ranger, replace, small, v10, vacuum, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
