Starter solenoid
Starter solenoid
Last Friday, when turning the ignition switch, the starter would spin, but not engage the flexplate. It only did it a couple times, and would work after several attempts. Didn't leave me stranded, but I decided to replace the starter and solenoid to be safe as this is my daily driver. Changed them out Friday night. Worked fine over the weekend.
Flash forward to this morning. Go out and try to start the truck and the starter is staying engaged and spinning the motor with the ignition off and key out. Popped the hood and pulled off the "s" wire to the solenoid with no change, then pulled off the ground cable by hand. Guess I didn't have it that tight. Anyway, It looks like the solenoid is stuck on. Jumped into the other truck and went to work.
Brand new Nascar Select solenoid. Probably made in China and will check the box when I get home. Common? The rebuilt starter had a sticker recommending replacing the solenoid.... Starter works good. Spins the motor over faster than the old one did. Old starter had an old Motorcraft sticker on it. In fact, everything under the hood looked original when I got it. Motorcraft hoses, wires, everything, like it was maintained at a dealer for its life.
Now I am just rambling...
Oh the joys of an old truck....
Think I am going to put the old one back in....
Pretty poor. The new one worked like 3 or 4 times then stuck.
The old one looks like original, 29 years old and hundreds, if not thousands of starts. Still worked when removed.
Also thinking I should have kept the old starter instead of turning it in for the core charge.
They do NOT make them like they used to.....
Sure enough, Made in China. Put the old solenoid back in (motorcraft with a D5 date code) and it works fine.
The guy behind the counter had the same problem with his Honda solenoid, another BWD Nascar Select.
$14 worth of credit towards a new $31 Motorcraft solenoid. Should have it tomorrow. Unless it says Made in China.....
Maybe I could rig up a knife switch and start it by hand....
Is BWD the same as Borg Warner? And does Nascar know they are putting their name on crap(my opinion) parts?
Like I said before, If the Motorcraft solenoid says Made in China, then I am going to return it, and go to the JY and get several for spares.
A lot of it is the regulations we have put on ourselves for safety, minimum wage, etc. Can't deny it is cheaper to make the items overseas.
I am willing to pay more for quality.
The NEW Motorcraft solenoids ARE made in China.
Old stock from a place like Rockauto should be okay.
Bill is right.
After swapping too many solenoids I finally bought a PMGR (permanent magnetic planetary gear reduction) starter.
It has the solenoid on it (like a stinking chevy) but it cranks just fine and only draws 40A to pull and 13A to hold.
May try it this weekend, but the old one still works like a champ.
Date/engineering code... blah. It says 1997 which makes me think NOS. Box looks old too.
