1997 ford f250 7.3 powerstroke diesel tranny swap - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-06-2011, 09:14 PM
lonemadjoker lonemadjoker is offline
lonemadjoker is starting off with a positive reputation.
I have a 1997 ford f250 7.3 powerstroke deisel with an automatic transmission. I also have a 2001 ford f250 7.3 powerstroke diesel with a 6 speed manual transmission. My question is can I swap out the tranny from the 2001 and put it into the 97 truck?
Old 11-06-2011, 09:18 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
You can, but it will require some modification... It bolts up fine, but I know there's some other things you need to change for it to work.
Someone who knows more than I do will chime in.
Old 11-06-2011, 10:01 PM
thank you what kind of modification will it take alot?
Old 11-07-2011, 07:08 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Yes, takes a lot of body modifications to the floor and tunnel to make clearance. I don't know much more than that.
Old 11-07-2011, 08:42 AM
79OldBone's Avatar
79OldBone 79OldBone is offline
79OldBone is starting off with a positive reputation.
OR a small body lift would probably make things work better if you dont want to cut the floor up?
Old 11-07-2011, 09:29 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
A lot of folks have swapped from an automatic to a ZF5. A few have swapped from a ZF5 to a ZF6. If you search and read the threads on both these topics, and combine the tips, tricks and wisdom of the two, you should be able to cobble together a plan and get a sense of the challenge ahead of you.
Old 11-07-2011, 12:23 PM
wildstang's Avatar
wildstang wildstang is online now
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
If you go to powerstrokenation 1994 to 2006 axle swap thread - Page 10 - PowerStrokeNation : Ford Powerstroke Diesel Forum guy there just posted a little about it. Maybe ask him some questions also. I think you need a new computer module or get yours reflashed so it knows it is a standard and won't be looking for auto tranny inputs.
Old 11-07-2011, 11:01 PM
You don't need a _new_ PCM. Just one from a '97 manual truck (van PCMs are different), and the same emissions (Federal vs. Calif) as your truck. This: PCM Codes - 1994-1997 Power Stroke FAQ might help.
Old 11-08-2011, 06:00 AM
wildstang's Avatar
VT Chapter Ldr
Quote:
I said basically the same thing but shouldn't have said new. Can't you get it reflashed though?
Old 11-08-2011, 07:24 AM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
You can get it reflashed but not necessary to run just fine but yeah it will run slightly better. You have to customize drive shafts because there was never anything the same length as a zf 6 on an obs truck. Also the 6 has a cooler and lines to deal with. Seems like someone on the know said it is perfectly ok to delete the cooler since its a manual though
Old 11-08-2011, 09:24 AM
If you run an automatic PCM in a manual truck, it will probably perpetually throw the CE light with a bunch of tranny codes.
If you have an aftermarket chip, you can also get that re-flashed, and as long as you don't remove it, it will "trump" the PCM.
Old 11-08-2011, 10:14 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
O contrar.... the auto pmc does not need any "inputs" from the auto tranny, in fact there are none in the E4OD. The only thing the auto PCM has that is different than the manual PCM is the smarts to shift the E4OD, which will no longer be there. So it will be trying to shift a non-existent transmission, but it won't even know it isn't there, because there are no additional sensors in the E4OD to feed back any info to the PCM. As I understand it the only difference in going from an auto PCM to a manual one is the way the fuel map looks. The fueling is slightly different, but should not affect driveability.
Obviously, you can't drop a manual PCM in an auto truck and expect it to work without re-flashing it to tell it to shift the E4OD, but going the other direction shouldn't really make any noticeable difference. I
f you're really worried about it have a chip with custom tunes burned and tell them what transmission you have.
Old 11-08-2011, 08:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
One sensor that will cause a problem is the MLPS. Another missing sensor is the transmission fluid temperature sensor (TFT.) The auto PCM is looking for those sensors and will set codes if they are missing.
Another problem is that the auto PCM is looking for two shift solenoids, one lockup solenoid, an electronic pressure control solenoid, and a coast clutch solenoid. Each one of those will set a code if they are missing.
7.3L Engine Swap DakotaC 1999 - 2003 7.3L Power Stroke Diesel 1 04-10-2015 03:09 PM
Swap engine 7.3 from 2001 f250 into a 1993 7.3 12pump 1999 - 2003 7.3L Power Stroke Diesel 0 08-04-2014 05:39 PM
1999 powerstroke 7.3 to 1997 heavy duty simplejack 1999 - 2003 7.3L Power Stroke Diesel 7 08-22-2012 11:06 PM
96 ford diesel f250 transmission switch mirage5058 1987 - 1996 F150 & Larger F-Series Trucks 8 10-16-2010 11:21 PM
1997 POWERSTROKE 5 SPEED! NEED TRANS PARTS! hinton08 1994.5 - 1997 7.3L Power Stroke Diesel 3 02-10-2010 10:12 AM
Tags
1996, 1997, 2001, 250, 73, diesel, f250, ford, forum, interchangeability, powerstroke, swap, time, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
