Bought bed, have questions
So I tracked down a 6ft bed for my truck. The metal floor was split and rusted so it got removed along with the rotted wood. Anyone have any experience with a good sturdy floor? I have thought about doing diamond plate and welding it in then having the liner sprayed.
Also, a bunch of the studs that the fenders bolt to on the bed broke off, any idea where I can get new ones? Thanks!
Northern Classics has the fender bolts. They look a lot like elevator bolts. Most are spot welded in, so if some broke off, you'll probably need to use a hammer and chisel to break the spot weld. If you're worried about denting up the bed side, you can use a grinder to carefully grind the head off, then punch whatever is left off with a hammer and punch.
If you're not too worried about the original look, you can just use some carraige bolts to replace the broken ones.
Dan
Dan
Thanks. I purchased the fender bolts, but struggled to get even one out. I thought I would ask before getting upset and messing up my bed sides. I guess I will try to grind off the one that is broken. I will then attempt to chase the threads on the other bolts and hope that they work. I never would have thought that they would have been spot welded on. I thought that if I heated them with a bit of MAPP gas, that they would come loose when hot. I may still try it. Either way the paint will be chewed up. Steve
Here is a great link that discusses it in detail with pictures: Ford F1 Rear Fender Replacement - Classic Trucks Magazine
Steve
Steve
