94 F250 I-beam bushings - Ford Truck Enthusiasts Forums
Old 11-06-2011, 06:32 PM
94 F250 supercab's Avatar
94 F250 supercab 94 F250 supercab is offline
94 F250 supercab is starting off with a positive reputation.
Are there any aftermarket bushings for the Twin I-Beams (2wd)
Mine are shot and dealer says you need to replace whole I-beam which
is no longer available. Any help appreciated
Old 11-06-2011, 06:39 PM
96B4000 96B4000 is offline
96B4000 is starting off with a positive reputation.
Are you talking about what I think are called axle pivot bushings? Replaced them on my 94 F250 2wd last year, from oreillys.. Moog I think they were...
Old 11-06-2011, 07:51 PM
These are in the center of frame under engine staggered , on end of twin I-beams in this location. Part # ? for Moog ?
Old 11-06-2011, 08:00 PM
K8620 go to oreilly auto.com type in axle pivot bushings, box of 2 - $49
Old 11-06-2011, 08:02 PM
Thanks !!!!!
Old 11-13-2011, 08:37 PM
Do you have to remove the I-beam or can these bushings be replaced by just droping the center part down ? Do the bushings need to be pressed in ? Any help appreciated.
Old 11-13-2011, 08:43 PM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
Not to go off topic or anything but, how did you know the bushings were worn out, or did the dealer tell you?
Old 11-13-2011, 09:47 PM
Quote:
I put a jack under the I, beam, removed the bolt and SLOWLY released the jack to lower the I-beam, I did not even take the tires off, pressed out the bushings, think it was a u-joint press, like a big c-clamp, the one side of it was big enough for the bushings to pass through it. Used pb blaster to help loosen the bushings, took an hour or so both sides total.
Old 11-14-2011, 05:57 AM
Quote:
I like to look underneath what I'm driving , I'm actually shocked at how bad they were egged out. Truck has around 235,000 miles. They are so bad I'm concerned the bolt could snap. I can't believe this was not noticed at last state inspection. I'll try to take a picture and post
Old 11-14-2011, 06:07 AM
Quote:
So far I have been told the whole I-beam needs to come off, but looking at it myself, the way you describe is how I thought it can be done.
My concern is trying to do this myself on the ground without the truck falling on top of me. The older I get the more chicken I get I guess.
I don't have a u-joint press but will have to look for one.
Thanks for quick response
Old 11-14-2011, 08:06 AM
I think you could do it with a heavy piece of all-thread, some thick washers and a short section of pipe to pull the bushing into, if you can't find a press, can usually rent/borrow one from a parts house
Old 11-15-2011, 06:47 PM
Did you have to change your bolts ?
Local parts stores around here are asking if my bolts are 1/2 or 5/8 , to get the right bushing
My bolts are metric and between the 2 standard sizes.
Old 11-15-2011, 07:30 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
You need to find a better parts department.
Part#8C2Z-3B177-A
MSRP $14.98 from FoMoCo
Old 11-15-2011, 08:41 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
I put Energy Suspension polyurethane bushings in both my trucks. On 2wd's, the poly bushings have to be installed inside the stock steel outer "cup" that goes around the bushing and presses into the I beams. When I did mine on my 2wd, I didn't even press out the cups. Just cut out the old rubber, ran some sandpaper around the cup to get all the left over rubber off of it, install new poly bushings, bolt I beam back in.
Took us less time to do I beam bushings on my truck than it took 2 guys to change a belt on an '06 Dodge with a Cummins in it. LOL
Old 11-15-2011, 08:45 PM
Quote:
Part#8C2Z-3B177-A
That's true , went to 2 different dealers both said SOL
I-Beam Question csm_274 1961 - 1966 F-100 & Larger F-Series Trucks 11 04-08-2016 05:06 PM
in need of wire schematics for 65 f250 I-beam WarSac 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-26-2014 12:39 PM
I-Beam Bushings andyz77vette 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-02-2011 11:54 AM
I-beam bushings lakex1 1967 - 1972 F-100 & Larger F-Series Trucks 5 07-27-2005 08:41 AM
Changing front suspension bushings loudfords 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-25-2002 06:42 AM
Tags
1996, 801079, 94f250, 95, ball, beams, bolt, bushing, f250, ford, ibeam, joint, n801079, n801079s2, removel, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
