Exhaust Fluid System Fault Message
My 2012 F350 Lariat has 6100 miles on it now and on the way home tonight I got a "speed limited to 50 mph in 50 miles" message on the display. It states that there is a "diesel exhaust fluid system fault". The def was topped off about 2000 miles ago and the message center says that the fluid level is "ok". I am going to be on the phone with the dealer first thing in the morning. This is my personal/work truck and if I can't tow a trailer then I can't work. My guess would be a faulty sensor. Just curious if anyone else has ran into this and what the problem turned out to be. I have no doubts that the dealer will get this resolved quickly as they have been great about everything else. I also want to say that other than this, I am sure minor issue, this truck is awesome! I love everything about it.
Jeremy
Jeremy
One of the many drive ability problems my truck experienced. The exact same scenario you experienced. I stopped the truck several times and tuned the engine off waited a few moments and restarted. The "speed"warning went out but the "repetitive" CEL stayed on. I think that was the first DEF pump replacement ( 3 DEF pumps as of now). Good luck!
Spent just over 2 hrs at the dealership. They followed Ford's guidelines for the problem which consisted of clearing the code, removing the def injector and running the pump to measure the amount of fluid coming out, drive the truck for 20 miles after injector was reinstalled and code was cleared.
Why do I have the feeling that this is not the last of this issue that I am going to see. No parts replaced just pretty much cleared the code. I just hope it doesn't happen again when I am a couple of hundred or more miles from home!
