timing chain problems? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 11-06-2011, 06:16 PM
qepv25a qepv25a is offline
qepv25a is starting off with a positive reputation.
I have a 99 expedition, 5.4 with 4X4. We pull a 6,000 lb travel trailer. when pulling up a grade the engine sounds like a tin can with rocks in it when you shake the can. I started using premium and the condition lessened. Now it happens less but the engine still will do it under extreme conditions, 3500rpms or so. All the cops have been replaced and it is tuned up. It has 155,000 miles on it. I read somewhere that a bad timing chain may cause this sort of problem. I was hoping that someone may have run into this probem. It is rated to pull 7500lbs., so we are at the upper limits of its tow capacity. Another problem started last week. A chemical smell and vapor come from the vents when the heater or air is on. It has a smell like antifreeze. Any ideas on this. On the timing chain any ideas on the cost to replace. Thanks in advance. Bob
Old 11-06-2011, 07:09 PM
fixit5561 fixit5561 is offline
fixit5561 is starting off with a positive reputation.
Cant help with the timing chain.
The smell of antifreeze and the vapor means you have a leaking heater core. Even with the air on the heater core still has the coolant running through it to some extent.
Old 11-06-2011, 08:06 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Exactly as fixit5561 said, heater core! While you are doing that I suggest that you replace the blend door also, as that is a common failure. A good radiator shop will charge about $450.00 and do both. If you get a better price tell the world as there are sure to be others in your area that will need this done this winter.
Old 11-06-2011, 08:36 PM
turborich's Avatar
turborich turborich is offline
turborich is starting off with a positive reputation.
Sounds to me like it has nothing to do with the timing chain and more to do with spark knock. If a higher grade of fuel lessened the knocking noise then perhaps you have carbon build up or an EGR problem? Does it run hot while towing? Heat can cause the pinging noise as well.
I tow a 3000lb camper with my 2000 5.4 expedition and it has 148k with no issues except for the lack of power the 5.4 exhibits while climbing grades.
Hopefully someone can point you in the right direction.
5.4L Timing chain guides JCount Expedition & Navigator 7 12-08-2016 11:21 AM
2006 Explorer timing chain issue kirka Explorer, Sport Trac, Mountaineer & Aviator 4 12-03-2014 12:54 AM
weird engine noise TheProfessorofTOOL Modular V8 (4.6L, 5.4L) 7 04-23-2013 09:31 PM
1991 E250 problems 1Fasteddie 1968-2013 Full Size Vans 2 11-19-2011 10:30 PM
99 Explorer 4.0 Timing Chains Kiroshu Explorer, Sport Trac, Mountaineer & Aviator 13 05-08-2010 01:41 AM
Tags
99, belt, chain, expedition, ford, i290, lincoln, navigtor, noise, oise, problems, slipping, timing, troubleshoot, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
