1976 F250 Highboy Car wash
i like the body lift idea were i already have one sitting on a shelf from a parts truck and im needing 1/4" to get the cab to line up with the bed just the matter of milling 1/4" off the rear mounts. my main issue with most body lifts is that the cab and frame get so far apart you can see a huge gap but it does not look like that is a issue on the high boys. do you have a straight on side pic i could see how the frame looks under the body?
Eagle-1 665804 - Etching Mag Wheel Cleaner | O'Reilly Auto Parts
I clean them with this and a stiff brush.
I use some HVAC coil cleaner. If you read the active ingredients in the Eagle One, then match them up in the coil cleaner, you can get it cheaper and undiluted. I can get it for about $8 a gallon. Don't even need to use a stiff brush.
Pretty much the same situation as mine was in.... Straight pipes are loud as hell especially when they dump anywhere near the cab, but obviously you already knew that
I had mine dumping like yours before the rear axle for a while, then I bought some pipe and fittings and clamps and got it out from under the truck and man it makes a hell of a difference in the exhaust note. I have mine coming out at 45 degree angles right before the rear tires. Looks good and sounds even better. Only cost me about 30 bucks.
Dang sharp truck and I like the rims BTW.
Yes those look like Ford factory bed rails. They mount in the factory stake pockets with a metal tab that goes in the hole and then tightens up with a bolt. No holes in the top of your bed.
Yes that also looks like a factory push bar, and no JBG do not stock them for full size truck/bronco only EB.
#30
What kind of tach is that? I have mine in the same location and its not working right. From what I've been told I need another one. I can't seem to by one only to take another chance of it not working.
