1976 F250 Highboy Car wash - Page 2 - Ford Truck Enthusiasts Forums
Old 11-07-2011, 02:05 PM
kilich kilich is offline
kilich is starting off with a positive reputation.
Quote:
Originally Posted by stuck in the 70s View Post
i like the body lift idea were i already have one sitting on a shelf from a parts truck and im needing 1/4" to get the cab to line up with the bed just the matter of milling 1/4" off the rear mounts. my main issue with most body lifts is that the cab and frame get so far apart you can see a huge gap but it does not look like that is a issue on the high boys. do you have a straight on side pic i could see how the frame looks under the body?
Old 11-07-2011, 02:08 PM
Quote:
Originally Posted by Grubbworm View Post
That sure is a nice looking truck you have there. I have those same wheels on my truck. What do you use to clean them? I use HVAC coil cleaner, and rinse very, very thoroughly. I love the look of those old highboys.
I clean them with this and a stiff brush.
Eagle-1 665804 - Etching Mag Wheel Cleaner | O'Reilly Auto Parts
Old 11-07-2011, 02:18 PM
Kalve's Avatar
Kalve Kalve is offline
Kalve is starting off with a positive reputation.
looks good
Old 11-07-2011, 02:19 PM
Quote:
Originally Posted by Kalve View Post
looks good
Thank you.
Old 11-07-2011, 02:25 PM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
Quote:
Originally Posted by kilich View Post
I use some HVAC coil cleaner. If you read the active ingredients in the Eagle One, then match them up in the coil cleaner, you can get it cheaper and undiluted. I can get it for about $8 a gallon. Don't even need to use a stiff brush.
Old 11-07-2011, 05:45 PM
Fordfreek!'s Avatar
Fordfreek! Fordfreek! is offline
Fordfreek! is starting off with a positive reputation.
Nice looking truck! I love those turbine wheels, especially on a black truck. Exhaust sounds good too. What size (length) glasspacks are you running?
Old 11-07-2011, 06:51 PM
Quote:
I think their 24-26 inchs not to sure.. and its 2 1/4 pipe.
Old 11-07-2011, 07:16 PM
Fordfreek!'s Avatar
Nice. I'm running dual 22" -ers on mine, sorta temporary but I like the sound.
Old 11-07-2011, 07:31 PM
Yea, I like the sound of mine.. use to be really loud cause of the straight pipe dumping at the cab corners. got annoying so i decided to do a system
Old 11-07-2011, 08:07 PM
Fordfreek!'s Avatar
Pretty much the same situation as mine was in.... Straight pipes are loud as hell especially when they dump anywhere near the cab, but obviously you already knew that
I had mine dumping like yours before the rear axle for a while, then I bought some pipe and fittings and clamps and got it out from under the truck and man it makes a hell of a difference in the exhaust note. I have mine coming out at 45 degree angles right before the rear tires. Looks good and sounds even better. Only cost me about 30 bucks.
Old 11-07-2011, 08:09 PM
Yea, this cost me about 150$ for my set up.. I didnt wanna run it out to the back of the truck, not a fan of that look.
Old 11-13-2011, 04:22 PM
Update on whats goin on.. Took the roll bar out. IMO looks better. Added a Tachometer, and a radio. the radio is in a temporary postiton till i figure out what im gonna do..
  #28
Old 03-16-2012, 11:13 AM
NZPUMP NZPUMP is offline
NZPUMP is starting off with a positive reputation.
What is the size and offset of your wheels ? We have a 1976 F250 Highboy and it still has the standard steel wheels and hubcaps on it.
  #29
Old 03-16-2012, 12:47 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Dang sharp truck and I like the rims BTW.
Yes those look like Ford factory bed rails. They mount in the factory stake pockets with a metal tab that goes in the hole and then tightens up with a bolt. No holes in the top of your bed.
Yes that also looks like a factory push bar, and no JBG do not stock them for full size truck/bronco only EB.
  #30
Old 03-16-2012, 04:33 PM
whistle1516's Avatar
whistle1516 whistle1516 is offline
whistle1516 is starting off with a positive reputation.
What kind of tach is that? I have mine in the same location and its not working right. From what I've been told I need another one. I can't seem to by one only to take another chance of it not working.
CB antenna Mount (Opinions) kilich 1973 - 1979 F-100 & Larger F-Series Trucks 33 01-23-2016 10:33 PM
Lund Racerback Visor kilich Ford Truck Parts for Sale 4 11-29-2015 07:58 PM
New to me 1976 F250 Custom flatbed dually w/ 460! klubvintage 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-13-2012 07:49 PM
1965 F250 Camper Special (Lots of Pictures) kilich 1961 - 1966 F-100 & Larger F-Series Trucks 32 08-08-2012 06:31 PM
Dana 60 Axle shaft Removal Help. kilich 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-04-2012 01:37 PM
Tags
1978, 460, 70s, 73, 76, bar, body, brakes, bull, f250, factory, ford, front, highboy, lift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
