#6 Cylinder location ? - Ford Truck Enthusiasts Forums
Old 11-06-2011, 05:00 PM
Slankky's Avatar
Slankky Slankky is offline
Slankky is starting off with a positive reputation.
Just to make sure I'm reading It correctly. Front of engine is front of truck (radiator end) so even # cylinders are on the Drivers side correct ?
Old 11-06-2011, 05:08 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Yea its third one back on drivers side .
Old 11-06-2011, 05:14 PM
Slankky's Avatar
Quote:
Ok than you
Old 11-06-2011, 06:32 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
radiator
2.............. 1
4.............. 3
6.............. 5
8.............. 7
drivers....... passanger
side........... side
Old 11-06-2011, 06:49 PM
Slankky's Avatar
Quote:
Originally Posted by cheezit View Post
radiator
2.............. 1
4.............. 3
6.............. 5
8.............. 7
Cool thanx. I thought so, but in tech folder was a little confusing with left and right, frot and back.
Need help with key cylinder Randy1944 1947 and Older Ford Trucks 3 11-12-2015 05:47 PM
1956 F500 Single Piston Front Cylinders? Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-15-2015 10:18 AM
Wheel cylinder upgrade for '67 Highboy? Gramps67highboy 1967 - 1972 F-100 & Larger F-Series Trucks 9 03-13-2015 03:39 PM
Correct engine color Mixer man 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 03-09-2015 07:27 PM
70 F250 Master Cylinder goodwin 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-03-2014 10:07 PM
Tags
150, 2002, 60, 6l, 6th, cylinder, diesel, diesellocation, ford, location, order, placement, supercrew, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
