F150 Front end noises
Old 11-06-2011, 01:03 PM
edub32's Avatar
edub32
edub32 is offline
I've been hearing some strange noises in the front end of the truck lately. First off, I noticed a CV axle on the driver's side has been leaking grease everywhere. I plan on replacing the whole axle shortly. But I've been hearing some popping and grinding noises more noticeable when the steering wheel is slightly turned. You can feel the popping and grinding on the floorboard. Does this sound like typical symptoms of a CV axle? I'm hoping it's not anything else.
Old 11-06-2011, 01:06 PM
danorules's Avatar
danorules
danorules is offline
i would say it does sound like the cv joint. winter is almost here so i would recommend repairing this promptly, you may not get too far with that bad joint with the 4x4 engaged
Old 11-06-2011, 01:51 PM
edub32's Avatar
edub32
edub32 is offline
Yep, it's definitely on my priority list. It seems odd that the popping just started to occur after I did some brake pads on the front. I vaguely recall a vacuum line on the front driver caliper that I had no idea where it plugged into. It ran in junction with the brake line. Could this be a loose vacuum line to the hubs?
EAWF250
6.2L V8
05-26-2017 03:06 PM
Pro2ndAm lib.
1997 - 2003 F150
07-08-2016 09:23 PM
glennemay
1999 to 2016 Super Duty
02-26-2014 08:32 PM
Jimha4444
01-02-2014 11:41 PM
JUMBO_UTE
06-16-2004 07:57 PM
Quick Reply: F150 Front end noises
