2.3L crankshaft position sensor - Ford Truck Enthusiasts Forums
Old 11-06-2011, 10:54 AM
CT CT is offline
CT is starting off with a positive reputation.
I need to change the timing belt on my 1992 Ranger 2.3L. Base, no power steering or air conditioning. Like a dummy I don't have a book. I pulled off the crank pulley and the gear it bolts to, but the crankshaft position sensor bracket still seems to be in the way of the belt guide (washer) sliding off and on. Do I need to remove the bracket too? I don't like messing with sensor stuff if possible. Also, I'm not seeing the timing mark for the auxiliary pulley.
I would guess it would point at the crank or the cam gear, but I'm not sure.
92 2.3L CKP - Replacing the Crankshaft Position Sensor RixWorx Ranger & B-Series 4 12-30-2015 04:31 PM
1989 2.3L - Stubborn crankshaft pulley 385seriesHemi Ranger & B-Series 9 10-27-2012 03:11 PM
Timing marks in a 2.3 staysbroken 4 Cylinder Engines 4 05-21-2009 08:23 AM
2.3L timing belt jmagers 4 Cylinder Engines 7 05-21-2007 09:53 PM
90 Ranger 2.3L crankshaft timing sensor alignment tool > Open to All Answers wolfen Ranger & B-Series 6 10-03-2003 02:36 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 23l, 92, bracket, change, cmp, crank, crankshaft, ford, location, mounting, position, ranger, removal, remove, removing, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
