Electric brakes on Winnebago
Hi folks, I've searched the forum and came up empty---1998 Winnie class A on a Ford chassis with factory tow plug. Just got a car-haul trailer w/electric brakes. Installed Tekonsha Voyager controller. It doesn't recognize trailer. The owner manuals (Ford and Winnie) both have diagrams for the recepticale which don't even include a pin for the brakes. What am I missing? Thanks
Jerry
Jerry
Jerry
Jerry
Do you actually have a seven pin or just a four pin receptacle. You could have either, but in any case, I would not expect a class A motor home to be wired with a lead for a brake controller.
Steve
If I were were towing behind a motor home with a trailer, which I guess is what you are doing, I would install a proper seven pin transfering the wires from the six pin and then run a line for your brakes. May take a little time, but should be pretty straight forward.
Good luck,
Steve
Steve
What I would do in this case is to first take some time at the rear of the Winnebago to see what I have. Motor homes are a real soup to nut mix when it comes to wiring for toads. The receptacle on the rear often sees little use so they also tend to be corroded. I would count the wires at the receptacle and take voltage readings to see what I have and don't have. Owners also often drag the rear ends tearing away wires, etc.
Another very simple thing you can do because Winnebago historically has a much better tech support than many companies is call them on the phone and ask. That will take away the possibility of wasting time.
I hate working on the wiring for the signal hookup on motorhomes because it can be maddening trying to trace wires when there is no standard. Some are not so bad, others just crazy.
Steve
Steve
Jason1228
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
02-27-2017 02:24 PM
tbax46
21
02-06-2015 08:52 AM
steveraymond
1999 to 2016 Super Duty
10-07-2010 04:14 PM
fire3110
09-23-2009 08:30 PM
SVTRanger
06-04-2004 05:55 AM
