Ice free windows ideas? - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-05-2011, 11:09 PM
bigblue61's Avatar
bigblue61 bigblue61 is offline
bigblue61 is starting off with a positive reputation.
I tried some spray that melted ice on contact which worked well when there was very very little ice on the windshield. What about putting vodka on the windshield the night before?
Old 11-06-2011, 01:01 AM
TRENT310's Avatar
TRENT310 TRENT310 is offline
TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.
Quote:
Originally Posted by dualwheels66 View Post
I buy the winter blend of windshield cleaner, start truck, turn on defroster wait about 2 minutes then hit the squirters and usually good to go.
Heh I've had a whole jug of -35C washer fluid freeze up before. Then I started buying the -50C stuff. When it's spread over a thin film it still freezes up regardless. Sometimes I forget and use the washer fluid spray button and it ends up getting harder to see through than if I hadn't done so.
Electric cab heater feature is pretty nice for this purpose though.
Old 11-06-2011, 01:23 AM
The Metal Panda's Avatar
The Metal Panda The Metal Panda is offline
The Metal Panda is starting off with a positive reputation.
Quote:
I did buy some RainX winter washer fluid.
And thatd be a waste of good vodka
So the shelter thing was a no, cardboard is a no, block heater is a no. AH this is annoying. I HATE winter
Old 11-06-2011, 07:50 AM
CPaulsen's Avatar
CPaulsen CPaulsen is offline
CPaulsen is gaining momentum as a positive member of FTE.
I use the windshield covers,,,,they attach with magnets. We get snow and sometimes down below 10 degrees with a lot of ice I have used a lot of de-icer which works also.
Old 11-06-2011, 08:18 AM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
Quote:
Originally Posted by The Metal Panda View Post
Im thinkin about building something like this.
Except way smaller. Just something i can pull the cab under.
My dad parks outside too, and he parks right next to my truck. So he might be down for this. Plus that would be free for me except helping him build it.
reminds me of a Metro bus stop cover thingie, but bigger
Old 11-06-2011, 08:35 AM
hanklin's Avatar
hanklin hanklin is offline
Ambassador
hanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputationhanklin has a superb reputation
Quote:
Originally Posted by pappy19 View Post
If you have or install a block heater, then keep it plugged in all night with the heater temp on cold (that keeps the heated rad water inside the engine), then go out and start the engine. Open the heater and put the temp on hot with defrost on high. Go inside and drink a cup of coffee. When you come back out, the windshield will be thawed. This is the college way. When you graduate and make those big bucks, then you can aford an alarm/remote start system after your first paycheck.
Pap
I`m the opposite. I plug in and then leave the dial all the way in the heated side. Warm air rises up during night and in morn windshield is clear and a warm engine.
Old 11-06-2011, 09:24 AM
Rudiak Rudiak is offline
Rudiak is starting off with a positive reputation.
Heet windshield de-icer works very good.
Old 11-06-2011, 10:28 AM
pappy19's Avatar
pappy19 pappy19 is offline
pappy19 has a very good reputation on FTE.pappy19 has a very good reputation on FTE.pappy19 has a very good reputation on FTE.
Quote:
Maybe I am wrong, but if the heater valve is closed then the coolant won't go through the heater core and it will take less electricity to keep the coolant warm just in the engine block vs the entire hose system to/from the heater core. Thoughts??
Pap
Old 11-06-2011, 10:54 AM
rs4-380 rs4-380 is offline
rs4-380 is starting off with a positive reputation.
Pap
pretty sure the block heaters don't cycle on/off. if they are plugged in they are on, which means no matter how big the body of fluid they are heating is they are always going to use the same amount of electricity.
Old 11-06-2011, 10:55 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
The temperature control dial has no effect on the heater control valve, nor on coolant flow. The heater control valve is closed by vacuum when the heater selector control is on MAX A/C and OFF. All other positions it is open. If you leave your truck turned off long enough, vacuum is going to bleed off and the valve is going to open anyway.
The temperature control dial only controls the position of the blend door.
Old 11-06-2011, 11:30 AM
PA-Mark's Avatar
PA-Mark PA-Mark is offline
PA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputation
I just read my post from yesterday. Sorry for all the misspellings, Im on percasets for a workplace fight with a 3/4 impact gun.... that I lost.
Old 11-06-2011, 11:46 AM
ak-angler's Avatar
ak-angler ak-angler is offline
ak-angler has a good reputation on FTE.ak-angler has a good reputation on FTE.
How 'bout just using a heater in the cab? Plug it into a timer so it's not on all night. Wake up to a warm cab and thawed windows.
  #28
Old 11-06-2011, 12:48 PM
Quote:
I wouldnt trust that at all. I'll take the risk of icy windows over a fire any day
  #29
Old 11-06-2011, 03:54 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
My dad leaves for work at 5:30 and for the last few years he's been laying a thermal (or other waterproof material) blanket across the windshield of his commuter car in the evening. He holds it down by shutting the top corners in the doors and lower edge under the wipers. Works great, in the morning you remove the icy/snowy blanket and you're good to go with a dry windshield.
  #30
Old 11-06-2011, 04:05 PM
8iron 8iron is offline
8iron is starting off with a positive reputation.
X2. They make ones specific to autos but the little ceramic cube ones work well. They have a t-stat, the housings don't get hot and they have tip over protection. We use them all the time up here in Canada.
rear defrost dcciie251 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-24-2011 05:07 PM
best tires for icy and snow coverd roads ? 1979BEAST 1999 - 2003 7.3L Power Stroke Diesel 16 09-28-2010 03:37 AM
Tug-A-War Contest? BartStar Ford vs The Competition 36 08-10-2009 07:21 PM
4wd on Black Ice or Icy Conditions ? JFUSION Escape & Escape Hybrid 6 02-10-2007 04:29 PM
AWD Aero Snow 96_4wdr Aerostar 20 12-05-2005 01:51 AM
Tags
04, 2wd, back, body, f150, f250, ford, free, ice, icing, lift, preventing, rack, shut, trucks, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
